Question about Electronics - Others
Can't place files on my Dane Elec Usb stick
I'm trying to put a few files on my Dane Elec USB stick but it keeps saying the file can't be moved to here without a reason why not. Do you know why it can't?
  • bill6576 Apr 13, 2009
    can't format keeps saying it's write protected can any one help??
    thanks.
    bill lawrence
  • 12,061 Answers
Well maybe it's full... check.. Maybe it's "Protected" in some way... maybe it needs to be "Shared" in permissions.. otherwise maybe it has gone kaput... hope not.. GL
Posted on Jul 29, 2008
I cant format my dane-elec a gb usb
click start control panel administration tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first
then return and tick the second box
you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on computer then right click on your usb drive select format
hope this helps you
Nov 12, 2011 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
My DANE-ELEC 4 GB USB has no files in it. I emptied it after using it during several months without problems with my MacBook Pro computer. However, after I threw all the files into the waste basket, when...
You need to format it. If you do this via windows in most cases you end up with an NTFS file system which means only windows machines will read it. If you want both windows and macs to see the files then you need to format MS-DOS. Easiest way to do this is with a mac using Disk Utility program.
Mar 23, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Hi, My 2gb red flash drive has all of my info on it, but it keeps malfunctioning---as in: the computer opens it, and then keeps opening it, until finally I get a message which says "Potable device...
Scan the device for Virus's first.
Secondly use CMD to copy off file(s): Make a folder on C: called USB. Then in command type: cd xcopy C:\USB /E /H /Y
Format the Device.
Dec 28, 2010 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
Hi, my dane-elec showing write protected. How can I solve it? I tried http://www.fixya.com/support/t345484-format_write_protect_usb_drive file but did not work. Need help. Thanks, Zia
Click > Start > Run > type "CMD" Then
Type "CHKDSK" and type the letter of your SD drive and "/F".
chkdsk Q: /F > press Enter
another example:
chkdsk D: /f
chkdsk E: /f
D or E is the letter or your SD drive.
May 04, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane 2gb memory stick 'write protected'
click start click to open on my computer you should see your usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
hope this helps you
Jan 14, 2009 | Dane-Elec DaneElec 4GB USB Drive Copper...
Dane-elec usb portable memory stick - right protect error
pu *** into you rown pc again and format it. when it is done formatting reboot your pc and let usb in while rebooting. when its done you can use it again but when used take it out with "safely remove hardware" option.
hope this helps otherwise they have a return and guaranty service at least
sorry for grammar but im not english
Jan 02, 2009 | Dane Elec DANE-ELEC DA-M4-04-ML2 Meizu 4G...
USB with plenty of capacity but apparently no availability
i just had this same problem. go to tools > folder options > view, and under hidden files and folders, click on show hidden files and folders. then click okay. then delete those hidden files, which were written overtime and stored onto the usb without your knowledge. the usb will have full memory space after you're done :)
Oct 06, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
Electronics - Others Logo
77 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
