Question about Brother SE-270D Computerized Sewing Machine
Brother 270D My machine has all of the sudden stopped embroidering. It's threaded correctly, new needle, bobbin is in place, etc... It sounds like it's working and then I notice the thread is not moving on the spool. and it beeps and tells me to check and rethread the upper thread. I've done that so many times I'm going crazy. Of course I'm in a time crunch for these items to be ready tomorrow. :o( Help....please.
  • 2 more comments
  • eowensby Jul 25, 2008
    I've cleaned everything out that I can see in the case. I can't seem to find anything in there that shouldn't be there. The top thread thinks it's embroidering for a few stitches and then the check and rethread notice beeps at me. :o(
    so far it has not overheated or completely shut down. it just won't stitch.
    Any idea where a thread sensor might be located or perhaps what it would look like?
    thank you for your help. I'll keep trying.
  • 6,487 Answers
Go to this link for the parts of your device so you can find the place for the hread sensor http://www.brother-support.co.uk/KNOWLEDGESTORE/PRODUCT%20BANK%20DOM.NSF/b93e4f013f58fa4c80256a9c0066e6ef/60e47039c4b8181880256dda003e5acf/$FILE/NV500D%20Parts.pdf
Hope that helps..............
Posted on Jul 25, 2008
    Genius:
  • 2,028 Answers
This has to have thread sensors, other wise it would run through the entire embroidery process even if there were no thread at all. Check the thread sensor or sensors, they may have malfunctioned, be misaligned, need cleaning, or be blocked by something.
  • Ryan Rogers
    Ryan Rogers Jul 25, 2008
    I'm sorry I don't. I've looked all over for a service manual for this machine and can't find one. I say follow the thread. It's got to be either behind the plastic cover in the front where the thread goes, or on the needle mechanism.
  • 818 Answers
The machine act's as if the motor gets hot and quit's. Once it cool's off, it will work again.
    Genius:
  • 1,269 Answers
There might be some clogged piece of thread at the bobbin. Better check thoroughly the machine if there are small pieces of threads or hair strings that are inserted which can block the rollers.
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
Brother 700e
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 16, 2012 | Brother SE-270D Computerized Sewing...
My needle is jammimg machine is making a grinding sound
try changing the needle-flat side goes to the back of the machine
try rethreading the machine top & bobbin make sure to get every thread guide
make sure the bobbin is inserted in the bobbin case correctly
Apr 03, 2012 | Brother SE-270D Computerized Sewing...
Brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
Feb 04, 2010 | Brother SE-270D Computerized Sewing...
I have a brother 270D and the upper thread keeps breaking (common i know) but ive done everything int he trouble shooting section of the manual.. its only when i embroider too. checked different tensions,...
I had the same problem with my machine and what was causing the problem was the use of the wrong size bobbin. Check and make sure you are using the right size (type a) and if you can get bobbins already wound it would be better. Hope this will help you
May 14, 2009 | Brother SE-270D Computerized Sewing...
Thread tangles under throat plate while embroidering
Could the little hook that is stuck over the bobbin area be the thread cutter? My thread cutter gets stuck there and I have to turn my machine off and then try to use the cutter to reset it to its "resting" position.
Nov 23, 2008 | Brother SE-270D Computerized Sewing...
My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Make sure that your needle is put in the correct way, there is a groove in the front of the needle, check with your finger nail, this is usually to be facing you, and make sure the thread is going through the tension holder correctly do not have the foot down when you are threading the machine,as this stops the thread from going through the needle tension holder.
Sep 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
Thread adjustment
Sounds like the bobbin tension is loose. Look at this website on their "repair" page where it explains how to adjust the bottom(bobbin) tension.
www.sewusa.com
Mar 05, 2008 | Brother SE-270D Computerized Sewing...
Top thread wraps around bobbin
Is it birdnesting under the bottom or it is actually getting tangled inside the bobbin case? I've had my machine for almost a year and don't think I've had your exact issue. Sometimes, when you do a stich over a already stitched portion, you may have a problem with the bobbin and I just generally stop and start it again. It is important that you use the correct needle and also use a good embroidery thread and stablizer. Another thing suggested is changing the needle after about every 5 designs. Also, check the bobbin case to make sure there's no fuzzies caught in it. I use "canned air" like you use on computer keyboards. I also only use 40 weight emboidery thread for the top and actual bobbin thread for the bottom. Other threads can really jam everything up. So it's been trial and error to find the right combinations. Good Luck!
Oct 30, 2007 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
