Question about Marantz SR-19 Receiver
Memory back up
Even after a very brief loss of ac power or if the reciever is turned off with the off button( not on stand by) I lose all my settings a must go about reseting stations,surround sound settings etc. The manual ststes they should be preserved for about 2 weeks by internal memory. Th av reciever works fine in every other way.
Thanks for any help. Bill
  • 624 Answers
There is a capacitor in the circuit for the micro. This particular capacitor is for saving the memory settings and it is most likely defective now. You will need to take it to a repair center and have them check it out for you. Replacing this capacitor should not be too expensive, but you never know how some shops are going to charge you.
I do not have the schematics for this model of Marantz or I would just tell you what capacitor it is. This capacitor acts like a battery in the unit. It only requires a very small amount of power to maintain memory settings and these capacitors work very well for that purpose. Many times you can find them on the display board. But, once again, unless you have experience working with these type of units you should not try it yourself. It is very easy to damage electronics if you do not know what you are doing.
Let me know if you need any more help.
Posted on Jul 25, 2008
My screen closes after brief pause, goes back to start and password, i lose my work, have to find it again.
pls go to power option and select advance power options. select lid and power button select battery and ac adapter option as hibernate or sleep
Oct 26, 2017 | Dell Inspiron Computers & Internet
CDX-GT4301P sony car radio loses station/settings memory intermittently.
At the back of the head unit, there are usually two power connections to the car battery live. One is via the ignition, and the other is (usually) a fused connection that connects directly to a relay or fuse that has constant power, even when the car is switched off. This constant power allows your head unit to hold its memory. If the loss of memory is intermittent, it could be a loose cable or corrosion on the fuse.
Oct 22, 2013 | Car Audio & Video
I set the levels for all the speakers where I want them to be set at. But when I turn the unit off I lose all the speaker level settings and have to reset them
Some recievers have both a "power switch" and a "stand by" switch. Here is the difference.
"Power switch" eliminates all power input and most likely the memory in the unit too just like your stating in your situation.
"Stand by" switch shuts down all major components but keeps a small ammount of power to the unit to conserve any stored settings
Jan 05, 2011 | Sherwood RD-6500 Receiver
My strde445 is 10 years old now...whenever I disconnect the AC power cord (even for a dew seconds) the Demo mode is activated...accordingly to the manual the DEMO mode should only be activated if the AC...
They don't actually say it in so many words but the "two week" comment and the Demo Mode startup on even the briefest power loss implies there is a battery or a charged capacitor for memory keep-alive somewhere inside the unit and it is dead or malfunctioning.
Maybe someone can add something more specific to look for. Either way, a tech needs to check it out.
My 8-year old Pioneer loses settings on extended power losses, too. Oh well.
Dec 28, 2010 | Sony STR-DE445 Receiver
Onkyo TX-DS777 does not retain settings after power loss
No internal battery, a large "SuperCap" on the main board acts as one. Look for C8007, 0.1 F, 5.5V.
Apr 26, 2010 | Onkyo TX-DS777
It will not send out a volume of faxes any more.Says memory full.
Try turning off and unplugging the machine for a couple of minutes, this should clear the page memory, then power it up and see where you stand.
Hope this is of some help.
Apr 23, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
Lexicon RV-8 wakupe failure
Did you try this....
In the event of a power outage, the RV-8 will display a BROWN
OUT!! PRESS STANDBY message. To turn the unit on, use the
STANDBY button. For more information, see “POWER
MANAGEMENT” on page 3-3....
"Setup" >> "Power Management"
Opens the POWER MANAGEMENT menu, which is used to automatically
put the RV-8 into standby mode during brownouts.
When set to ON, the RV-8 detects low voltage levels or a momentary
loss of power and puts the device in standby mode. In the event of a
power brown out, the RV-8 will display a BROWN OUT!! PRESS
STANDBY message. To turn the unit back on, use the front panel
STANDYBY button.
When set to OFF, the RV-8 will attempt to function during a
momentary power loss, however software settings may become
corrupt and need to be reset.
When the RV-8 is in standby mode, pressing the button turns the
unit on and activates all zones that were active in the previous
operating session.
The RV-8 does not power on.
1. Make sure the rear-panel power switch is set to the | (“on”)
2. Attempt to power on the RV-8 with the front-panel Standby
button and remote control On button.
3. Examine the power cord to ensure a good connection between
the rear-panel AC input connector and the wall outlet.
4. Check the electrical circuit and breaker.
Apr 05, 2009 | Lexicon RV-8 V2.0 Amplifier
Input setting
When you turn off the set, are you turning it off by running the power through a cable or satellite box? If you are shutting down the set from the AC mains side the set can lose all of its user set-up. In most TV models, the main power supply must have the AC mains connected.
The power supply goes in to a standby mode when the TV is turned off by its own power switch (not by the AC mains). The supply puts out enough power to keep the uPC and the user memory active.
If the set is properly turned off and it is losing its user set-up, it is possible that there is a fault in part of the uPC circuits. Depending on the model of set, there may be a lithium battery, or memory capacitor, or an EEPROM for keeping the user set-up memory.
Jerry G.
Apr 18, 2008 | Polaroid FLM-2011 Television
Wrong date on the radio.
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Marantz SR-19 Receiver Logo
297 people viewed this question
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
