posted by ambarina on Jul 25, 2008
I have a RCA D52W20 52 in. Rear Projection HDTV-Ready Television, and when I use the digital cable, the convergence is off, and it's even worse on HD channels. The convergence is fine on regular cable. I even tried swapping my cable box. Any suggestions would be greatly appreciated.
Best Solution
posted on Jul 29, 2008
convergence for the rca itc222 is set individually for digital and analog tuner. Most of time the set will have to be converge in service mode. as a tech i would not recommend getting intoservice mode. but the key is the the convergence has to be set indiviadually for each tuner. You could try autoconverging in digital or even manualy converging
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for RCA D52W20 52 in. Rear Projection
Email this problem
Email this problem
Can you Help with these Projection Televisions problems?
RCA D52W20 52 in. Rear Projection HDTV-Ready...
D52W20B says HDTV/Monitor on...
How do I get WindowsXP to... Answer This...
picture size off with 1080i
My RCA D52W20 when using... Answer This...
Direct TV Hookup
Direct TV Hookup
My cat walked on my RCA remote... Answer This...
52" RCA TV Plus color TV...
There is power, there is sound,... Answer This...
my rca 52 inch hdtv turns...
We turn the tv on and then... Answer This...
Repair Service
Find Projection TV Repairman Near You:
Find Parts
