Question about Bose Acoustimass 15 System
Acoustimass V20 will not power on - no light on
We just bought (used) this entire V20 system. The previous owner swears it worked great before she packed it up. We've hooked it up (and everything really looks like new), but the module does not even light up on the back next to the plug. In the set up directions, it says to turn on the module, but we can't find a switch or button anywhere, just the light that doesn't do anything. Any suggestions?
  • Anonymous Jan 06, 2009
    i have a new v20 and it is doing the same thing. I am contacting cs tomorrow. Check back I will have an answer then.
simplemitch
  • 752 Answers
SOURCE: Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Posted on Aug 05, 2008
  • 51 Answers
SOURCE: Changing the inpout voltage of inside bose Acoustimass module
Probably not, but you can install a step-down transformer if there's room inside the unit. Since these speakers don't use much current, a small transformer will work. It doesn't have to be a 220-to-110 transformer either - any transformer designed to cut the voltage in half is fine. A 24 volt-to-12 volt transformer will also work.
Posted on Dec 27, 2008
  • 51 Answers
SOURCE: Bose Powered Acoustimass 30 Speaker System
The master on/off switch will usually be on the back (or maybe even the bottom) of the largest component, which contains the power and control circuits.
Posted on Dec 28, 2008
  • 3 Answers
SOURCE: BOSE ACOUSTIMASS SYSTEM 15 SUBWOOFER - NO POWER
All I did was unplug my surge protecter for a 1 minute and once I did that I had bass from the module again.  I am using a Belkin PURE AV power console.
Posted on Feb 11, 2009
  • 5 Answers
SOURCE: Bose Acoustimass power
I have the same problem TOO!#$#@% Anyone out there?
Posted on Apr 10, 2010
Tip
Bose LifeStyle V20 Manual Download
Download Bose LifeStyle V20 Audio System Manual
Would you like to review the features of the Bose LifeStyle V20 Audio System?
Have you lost your Bose LifeStyle V20 Audio System Owners Manual?
Would you like a digital, searchable, pdf version of the Bose LifeStyle V20 Audio System Users Guide?
Follow this link (& click FREE) to download a pdf version of the Bose LifeStyle V20 Audio System documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Audio Players & Recorders
Tip
I hope that helps.
on Jul 03, 2010 | Bose Lifestyle V20 System - black Theater...
I just bought my V20, I plugged it using a HDMI from my dvd to my v20 for the image, and a digital cable for the sound. My image works perfectly but I have no sound. I noticed that the light under my...
Hi - Don't know about the switching LEDs but there is no reason to be using both the HDMI cable AND a digital coax cable to the V20.
You should have a single HDMI (carries video and 5.1 audio) cable from the DVD to the DVD input in the V20.
Regards,
Mikeywaf
Mar 19, 2011 | Bose Lifestyle V20 System - black Theater...
Is the subwoofer from the Bose acoustimass 10 series IV Home Entertainment Speaker System a power sub?
The entire speaker system is passive. That is, it requires amplification for each channel.
From the manual: "Compatible with A/V receivers rated from 10 to 200 watts per front channel and 10 to 100 watts per rear channel; rated from 4 to 8 ohms".
Dec 09, 2010 | Bose Acoustimass 10 Series IV Home...
Tip
I hope that helps.
on Jul 03, 2010 | Bose Lifestyle V20 System - White Theater...
No sound from rear speakers of Bose V20
Are you useing a digital coaxil cable? or optical cable?(you will need one of these connections to get 5.1 surround!) the white /red rca jacks will not do the 5.1 surround! (back speakers)
Please rate response!
Jan 07, 2009 | Bose Lifestyle 12 System
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Attaching a pair of Floor standing speakers as Front R and Front L instead of standard bose cubes
yes of corz,, u can use any of that but dont go pass the power of your power amp,, becoz,, it coss damage 2 your speakers,, and thats expensive... ps. . dont revers the polarity
Feb 20, 2008 | Bose Acoustimass 15 System
Bose Acoustimass 15 System Logo
463 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
