Question about RCA Universal Remote Control
Wont turn on my Magnavox tv
Tried all four methods suggested in instructions and have unsuccessful in getting it work,
  • jimzill Jul 26, 2008
    My RCR311W universal remote won't work on my Magnavox TV model # 51mp610D737 What is the correct 4 digit program code ? I tried the steps listed on the remotes instructions and used the code list provided
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): wont turn on my Magnavox tv - clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
How to remove a broken stud in head
Some times the broken stud will not come out and will have to be drilled and a heli coil installed if all other methods are unsuccessful. What I try is drilling a hole in the stud ( !/8 drill bit ) and using a torx socket tap it into the hole with a hammer and use a ratchet. If the stud is going to come out, this method usually works.
Dec 19, 2015 | Cars & Trucks
Vulcan Gas Heating Furnace Pilot Light Goes Off
Clean pilot may be too small blow out with tube or air line , thermocouple not working try changing it
May 19, 2012 | Heating & Cooling
Need unlock code for nokia e71x phone plz,,,,,,,,
you can get the unlock code for your Nokia E71X model mobile, through this site http://www.theunlockarena.com/nokia-e71x/rs13wp9/
It has the best instructions and easy methods for unlocking mobile phone.......
Sep 30, 2010 | Cell Phones
Received the following message when I tried printing - "System Error. The printer failed to print due to a system error. Try printing again. If unsuccessful turn Windows off and reprint." Can you sugg
Turn it off and unplug it for about 30 seconds. Plug it back in, turn it on and try printing a Self-Test (Setup, 2, 5). If this works, try printing your document again.
Apr 14, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Restored factory settings on pc & cant re -instal belkin adaptor
The Belkin site has very specific instructions for installing this adapter in a pc with Vista. These instructions are at: http://www.belkin.com/support/article/?lid=en&pid=F5D9050&aid=6112&scid=0
I would first unistall any Belkin Software that has already been installed, shut down the system completely and then restart. After you have fully restarted the system then follow the Belkin Site instructions EXACTLY. Any variation is apt to mean an unsuccessful install. Good Luck and have patience.
Nov 14, 2008 | Belkin 802.11g Wireless Desktop Network...
Trying to synch my SanDisk MP3 player to Rhapsody
This player is a little goofy. The normal method to synchronize is through Windows Media Player. But if you go for the Rhapsody subscription, you have to also sync the device through Rhapsody.
-Tha Mp3 Doctor
Nov 13, 2008 | SanDisk Sansa Clip MP3 Player
WHIRLPOOL DUET DRYER
I've searched around for DIY instructions, but those are exceedingly difficult to locate. It seems that Whirlpool wants you to buy their Door Reversal Kit for 11.99 in order to accomplish this.
http://www.whirlpool.com/catalog/accessory_product.jsp?parentCategoryId=375&categoryId=376&productId=895
Jan 07, 2008 | Whirlpool GEW9250 Electric Dryer
Bose 321-GSX.
Not familiar with unit, but you can try a couple of things. Have you tried to play DVD's and CD's? If they both don't work you may have a laser problem. You can also hook up an external DVD/CD player to the coax and/or optical inputs and see if that will work. If this does, than you can still use the unit with an external source component. If that doesn't work you may need a new unit.
Jul 10, 2007 | Bose 3 2 1 GSX System
Televison & Video Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
