Question about Whirlpool Refrigerators
Icemaker Model #ED25RFXFW81 stopped making ice. Help!
catriver
  • 878 Answers
SOURCE: My subZero Model 245 Icemaker stopped making ice
Ice maker, I don't know where you can find the manual but I'll give you a few ideas of what to look for. First make sure that the inlet tube is not frozen over. Next, look at the center gear on the module and see if the clips in the center are not broken. If so you will have to replace the module. The ejector blades should be at the 2:00 position when home. If you get a jumper wire and jump T to H, this will by pass the bi-metal and run a cycle. The ice maker should fill at around the 12:00 position. Test points L & N will verify if you have 120v to the ice-maker. Test points L & H will test the resistance of the heater, 72 ohms. plus or minus 10%. Hope this gets you going, Catriver...post back.
Posted on Aug 21, 2006
watugot
  • 290 Answers
SOURCE: icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Posted on Oct 25, 2007
  • 109 Answers
SOURCE: ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Posted on Mar 28, 2008
  • 76 Answers
SOURCE: samsung rf267aars icemaker stops making ice
unfortunately it sounds like you have a broken tooth on the drive or driven gear of the ice maker, in this case you should replace the ice maker. The good news is that you can get a new one for about 85 bucks at your local appliance parts store.
Posted on Jun 23, 2009
SOURCE: Amana free o frost refrigerator
My fridge makes a loud rattling noise when turning off and on
Posted on Dec 29, 2009
Amana model tg21vl stops making ice
pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
Feb 24, 2013 | Refrigerators
How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
Jan 11, 2013 | Refrigerators
I have a Kenmore 55602400 Coldspot and the icemaker has stopped making ice. What do I need to do to fix it?
The model number you listed is for an air conditioner. Please check inside the refrigerator for the model number?
Oct 15, 2012 | Kenmore Refrigerators
Ice cube tray won't stop making ice.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
Thank you
Rick
Mar 12, 2012 | Refrigerators
Ice Maker stopped making Water Whirlpool model (ed5phexnq00)
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | Refrigerators
Ice maker not making any ice
check water valve or it is the icemaker water valve have two side one side icemaker other side water
Jan 19, 2009 | Kenmore 53082 / 53084 Side by Side...
Kenmore Side By Side Refrigrator ICe Make Not working
Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker want stop making ice
Oct 25, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
