Question about Panasonic AJ-D230H DV/Mini DV VCR
Firewire Card Needed
I am looking for a Firewire Card for the AJ-D230H deck, but apparently nobody has them anymore - including Panasonic. I believe the Part Number is something like AY-D230H. I was told Panasonic only made a limited number of the boards thinking most people would use the decks composite video & audio jacks and are not making the Firewire boards anymore.
    Problem Solver:
  • 4 Answers
Ebayd AJ-D230H got four sellers of the deck, maybe ask the sellers what else they have for accessories
Posted on Jul 27, 2008
Firewire not working.
Seems likely. FireWire connectors use dip switches to signal to the computer what inputs and outputs it needs
Nov 13, 2017 | Panasonic AJ-D230H DV/Mini DV VCR
Where does USB from DVC Pro deck to into Mac hard drive?
AJ-D230H doesn't have a USB connection. A firewire interface is an option, but they're very hard to find; have been discontinued by Panasonic.
Feb 13, 2010 | Panasonic AJ-D230H DV/Mini DV VCR
I have a panasonic dvcpro aj-d230h deck and i keep getting an E-00 error...does anyone know how to fix this ?
Err-00 lights when servo disturbances continue for
3 or more seconds during playback, recording or
I have seen this problem before, and it was due to a bad servo board.
Nov 19, 2009 | Panasonic AJ-D230H DV/Mini DV VCR
Digitized picture playing out from Panasonic AJ-D230H
There are several PCB's in the DVC:
Input TBC
Video IO
Mechanical \ IF
Digital Core
all of these boards have lots of, electrolytic can, surface mount capacitors:
upon researching the MFG specifications of the caps used by Panasonic, i found that they have a lifetime use rating in hours at a given temperature..
3000 hours of use at 100 deg c
these caps dry up and the power supplys get noisy and the caps that are employed in time constant circuit applications function out of spec ( if at all )
For about 3 months have been refurbinshing units successfully by replacing all of these caps
panasonic makes all of thes caps available as a service part kit
however the pcb's are very deleicate
I am only successful because I have 15 years of electronics engineering ecperience..
there is a tool call a Capacitor ERS analyzer ( Equivalt Series Resistance )
a good cap will measure .25 to 2 ohms and anything above 5 ohms is stale
I am getting set up in a new building for serviceing 230's and 255's at first and then i'll expand
I use a electronics assembly house to do the replacment of alll of the cap that go stale.
I have put together caps lists and digikey part #'s and generated my own re-capping kit that is much cheaper that the kit offered bt panasonic.
if you are interested in my services I am Ed
Mar 26, 2009 | Panasonic AJ-D230H DV/Mini DV VCR
Tape format playback for AJ-D250
menu item 107 can be used to select dv playback
Dec 08, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Hey dude
Yes you need to use th AJ-CS750P on the 230, I have had it work with almost every type of DVCpro machine.
Sep 19, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Panasonic aj-d230h
without knowing the exact error message, I can only speculate, but most rewind errors I have seen with the AJ-D230 are related to problems with capacitors on either the reel motor driver board or the system control board. the firewire upgrade (AJ-YAD230) is no longer available.
Error E-11
most common cause for this problem is defective electrolytic capacitors on the mechanical interface board. a good electronic tech should be able to replace them.
Mar 02, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Audio Problem with Firewire
The input select switch on the front of the AJ-D230H needs to be in the "OPTION" position, not "LINE". That may help if all the other settings are correct. You will also have to make sure that you have selected the right codecs for the deck that you are using in the software. I am speaking as a Final Cut Pro user so only offer this as a suggestion as these are the things that work from out of Final Cut.
Good luck. It can be very frustrating, but awesome when it all comes together and works right!!!
Oct 24, 2007 | Panasonic AJ-D230H DV/Mini DV VCR
Panasonic AJ-D230H DV/Mini DV VCR Logo
178 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
