Question about Car Audio & Video
Overheating, Check Engine Light On
1990 Toyota Corolla
Overheating - have to fill the radiator and overflow bottle every time we use the car, but doesn't appear to be leaking.
Runs rough in idle and sometimes on highway
Twice blew white smoke out exhaust, but other times was normal.
Check engine light comes on at times.
We don't have money for big repairs, but guess we have to do what we have to do - thought we would check with you guys first.
Try checking your water pump. Maybe it is not functioning the way it use to function. It affects your engine temperature. If your Water pump is running ok. Then have your engine analyze by an engiine analyzer. All they have to do is hook up to ECU to a computer and analyze the whole engine performance.
Posted on Sep 02, 2008
Overheating on acceleration up hills
Check the timing belt or what ever you have on that engine
Also have the coolant tested for exhaust gases,you may have
a head gasket issue
1990 or 2008 ? big different there as to wether you make
a major repair if nec
Jul 26, 2013 | 1990 Toyota Corolla
How do you properly bleed the coolant system on a 1994 Toyota Celica 1.8 stx?
If even possible, it sounds as though your water
pump is not turning the right way
It isn't even moving any water & that is all
you worked on, unless the thermostat somehow
could go in backwards
Nov 17, 2012 | 1994 Toyota Celica
Overheating
When was the last time you flushed your radiator?
Start with a radiator flush. Could be that simple
Jul 20, 2012 | 1994 Toyota Corolla
Heat is not working - coolant was low so filled it.... problem here... heard something about an air pocket
If you dont have an external coolant leak anywhere under your hood that has shown up on your driveway it could be the intake manifold or the headgasket leaking. Also check the thermostate to solve the heat issue.
Jan 05, 2011 | 1998 Pontiac Bonneville
Overheating
Check coolant level in the rad fluid overflow bottle.
If level is ok, check if the rad fan is working.
Also check if you are getting heat inside the car if you put it on hot with the fan on full. If there is no heat, it is probably the water pump that circulates the coolant
Apr 26, 2010 | 1990 Toyota Corolla
It really does overheat a lot when in traffic.
You need to check youe water pump, thermostat and your radiator cap and if all of that is good it sounds like a blown headgasket.
Mar 08, 2010 | 1990 Toyota Corolla
Spark plug sound from the radiator
That sound could be whats called air-bound, need to purge system, Fill radiator, run engine for about 4 minutes at idle, turn off let cool down for about 5 min then being careful recheck coolant in radiator, top off fluid then repeat, make sure overflow bottle is full, After about 3 times when radiator stays full run about 15 min and listen for radiator fan motor coming on
Feb 06, 2010 | 1990 Nissan Maxima
Overheating
there is a coolant cap on the overflow bottle check it for seal
i'd just replace it
also if you put the new thermostat in backward the overheating would be significant
Apr 21, 2009 | 2000 Lincoln LS
Car Audio & Video Logo
677 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
