I installed #v220cordless mouse but can not get it to work. I put the wireless receiver into the usb port the battery in to the mouse turned it on downloaded what was recomandedbut nothing happened
  • 70 Answers
There is usualy a button on the reciver and mouse that need to be pressed to sync them sometimes u have to use a sharp point to get to it
Posted on Jul 25, 2008
  • 689 Answers
Please make sure Set Point software, connection utility and desktop manager installed properly. If you dont have, you can easily obtain from link below
http://www.logitech.com/index.cfm/428/3295&cl=us,en?softwareid=671&osid=1
Good Luck
How to install 2.4Ghz wireless mouse with USB receiver?
Insert the batteries into the mouse. Turn the mouse over, find the battery cover, and slide it off. Insert the appropriate batteries-usually two AAs.
  • The wireless receiver that plugs into the computer uses USB power, so it needs no batteries.
Connect the receiver to the computer. If your computer has a USB port (as most do), plug your receiver into an available port. There will also be a green adapter supplied, in the event that your system requires the use of the mouse port. Caution-don't try and force the mouse adapter into the keyboard port!
  • The mouse receiver has a USB plug (left), but can also plug into the mouse plug through the adapter it came with (right). If your receiver plugs into the USB port it should look like the left. If it plugs into the mouse plug it should look like the one on the right, only connected to the receiver.
Connect the mouse to the receiver. Place the mouse in close proximity to the receiver, and note the following:
  • The receiver should have a visible button that is easily pushable by the average human finger.
  • The mouse will usually have a very small reset button in a hole on the bottom that can be pushed by something like a pencil or paper clip.
  • Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
Find a permanent position the receiver. Place the receiver where it won't be far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk.
  • The furthest a wireless mouse can get away from the receiver and still function is about 9 feet (2.7 meters), so keep that in mind.
Test your new mouse.
  • If you plugged into the mouse port, restart your computer.
  • If you plugged it into the USB port you should be able to use it immediately.
  • When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Adjust your mouse settings. Use the control panel that came with your wireless mouse, or download the necessary software from the manufacturer's website. Adjust the settings so that the mouse performs as you require.
Oct 18, 2014 | Computers & Internet
Microsoft wireless mouse model 1007 , will not work
  • Put in the batteries Find the battery covers and slides it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
  • Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
  • Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily push able by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
  • Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without working very well is about 9 feet (2.7 meters), so keep that in mind.
  • Test your new mouse.
If you plugged into the mouse port, restart your computer manually.
If you plugged it into the USB port you may begin using it.
May 16, 2011 | Microsoft Wireless IntelliMouse Explorer
Hello how do i get the wireless mouse to work on my laptop? i have it plugged in but it doesn't work
1. Put in the batteries Find the battery cover and slide it off. Insert the appropriate batteries. The wireless receiver that plugs into the computer runs off the computer's power and needs no batteries.
2. Plug in the receiver to the computer. Usually the receiver will plug into the USB port, but some plug into the mouse port. If all of your USB ports are filled, see if the mouse came with a USB adapter. The adapter fits into the mouse port. Be careful not to accidentally force the mouse adapter into the keyboard port.
3. Connect the mouse once you have it plugged in. The receiver should have a visible button that is easily pushable by the average human finger. The mouse will usually have a very small hole with a button inside it that can only be pushed by something like a pencil or paper clip. Push both buttons at the same time with the receiver and the mouse relatively close to each other for about 5 seconds or more.
4. Position the receiver in a place that isn't far away from the mouse. Depending on where you are, you can place it on the monitor, on the tower, on the back of your laptop (if you are installing the mouse to your laptop) or on the desk. The furthest a wireless mouse can get away from the receiver without not working very well is about 9 feet (2.7 meters), so keep that in mind.
5. Test your new mouse.
- If you plugged into the mouse port, restart your computer manually.
- If you plugged it into the USB port you may begin using it.
- When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Hope this help. Goodluck!
Mar 27, 2011 | Computers & Internet
My wireless mouse has stopped working
Wireless mice require batteries, unlike many USB, products, which are powered by the USB port; a wireless mouse is one of the devices that are not. Manufacturers, such as logitec and microsoft, have cleverly concealed the batteries inside the mouse, either under the place where your palm rests (older models) whereas newer models may have a battery compartment door underneath.
The only part powered by your USB port is the transmitter (the 'dongle') that is plugged into the USB port . You have to change the batteries every once in awhile. Some models put themselves into a sort off standby/off mode if you don't touch them for a certain period of time; others have tiny On/Off switches underneath. If you have one of those, remember to turn your mouse off, overnight, or when you aren't going to use it for long periods of time.
Thank You For Choosing FixYa~!
Mar 17, 2011 | Acer Computers & Internet
Mouse model 1007 does not work. lights are both lit one on mouse one on receiver but cursor doesnt move. hit the connect button and still nothing. Your help would be greatly appreciated.
Remove the battery and put it back again
Try plugging the receiver in a new USB port and install the drivers again. If it is already installed, make sure the Mouse is being detected by viewing it in Device manager.
After following the above steps, you can press the connect button to sync up with the receiver.
The issue can most probably be related to corrupted/hang drivers so you can try restarting the computer and changing USB slot for receiver.
Mar 12, 2011 | Microsoft Wireless IntelliMouse Explorer
How do i connect my wireless i.t.works optical mouse model MWO03 to my eee laptop windows 7?
Follow these steps :
1.
Check to see if your laptop supports wireless technology (Bluetooth, 802.11 or other). If it doesn't, you will need a wireless receiver. If it does, verify that your laptop is compatible with your wireless mouse, which could use either Bluetooth technology or a radio signal.
2.
Unpack your mouse and open its battery compartment. The wireless mouse won't receive any power from the laptop, making batteries necessary.
3.
Add new batteries to the compartment. Make sure that the + battery end is inserted into the + niche in the compartment.
4.
Place the mouse where it is easy to use and least stressful on your fingers.
5.
Place your wireless receiver appropriately if your laptop doesn't support wireless technology. The receiver should be kept at least 8 inches away from the laptop or any other object that would cause any interference.
6.
Place the wireless receiver anywhere from 8 inches to 6 feet from the mouse.
7.
Insert the driver CD into your laptop and follow the instructions to install the software for running the mouse.
8.
Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop. If you do not have a free USB port, simply use an external USB hub for more ports.
Nov 07, 2010 | Computers & Internet
Wireless Logitech mouse with NO connect button on it. Only buttons on it are Power and Reset (and one to open battery case). Cannot figure out how to connect to receiver. Was previously connected, but I...
Ok, try this in the steps ordered
1 remove the receiver from the USB port
2 remove the battery from the mouse
3 turn on the pc
4 after everything is loaded on the pc, plug the mouse receiver into the USB port
5 put the battery back in to the mouse and let it "find" the receiver.
If these steps don't work, try doing the steps and use a different USB port. If that doesn't work try a different battery in the mouse.
If none of this works and the receiver hasn't been bent (happens allot in laptops), then it sounds like your mouse took a dump.
Mar 18, 2010 | Logitech Cordless Mouse
MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 20, 2009 | Computers & Internet
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
Computers & Internet Logo
41 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
