Question about Maytag Refrigerators
Maytag fridge leaks under the door on right hand side. tray in dry
  • 254 Answers
Check your defrost drain line it may be clogged
Posted on Jul 25, 2008
Maytag side by side door slamming shut
what's the model number and what's happening with it,do you mean the fridge is on top and freezer on bottom?open the fridge door,look up on right hand side up near ceiling and send the model number and the first two numbers of the serial number
Jun 18, 2012 | Maytag Refrigerators
My Kemore refrigator is leaking water from bottom,I keep moping and I put news papers under to absorbe the water.where is the water leaking from ? Its about 8years not sure, but never a problem.It has a...
Under your fridge, there is a drain hose which goes into a removable tray on the bottom of your refrigerator.This is where the water from the automatic defroster goes. The heat from the motor dries the water up, but occasionally the hose becomes plugged, or does not set into the tray. You may have to pull the fridge away from the wall, go behind the fridge, get down on the floor, find the tray, in the front or back, check that the hose is in place and patent. If the tray is full of water, there may be a heating or evaporating element that is not working to dry up the water, in which case you could always manually empty the tray till you you find a solution. Good luck.
Jun 20, 2011 | Kenmore Refrigerators
Condensation is forming on the glass door and dripping onto floor boards. How do we stop the condensation. It does say to empty drain tray but we cannot find it and instruction manual does not tell you...
The drain tray is under the fridge often times set back a little bit. Remove the kick plate by pulling from one side then the other side, strait forward till it pops off. The kick plate is a plate as close to the floor as you can get on the front side of the fridge going the entire width of the bottom of the fridge. Now get eye level with the underneath of the fridge. Center your view on the underneath of the fridge. The drain tray is right there. Pull it out, carefully as it is probably full of water, and dump the water out of it. Replace the drain tray and then replace the kick plate. Check the drain pan once a week or so and you should have no more water leaking on your floor. Hope this helps.
Mar 22, 2011 | Refrigerators
Water has collected and frozen at the bottom of the freezer compartment. From time to time I get small leaks on the floor beneath.
There is a drain tube from freezer/fridge and stops under the fridge and allows water to drip into an evaporator tray. The drain tube/hose can get blocked up, it is very common. Free up the tube and you will be good to go. Sometimes just snipping on the very bottom to make a larger drain hole works too.
Feb 05, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Hi I have a Maytag fridge freezer GC2227CDFB The fridge compartment has stopped working, the lights still come on when door open, the motor seems to be working, when temp. setting is turned down to 0 the...
Your problems are exactally the same as mine. I have taken the freezer back panels off and fornd the elements blocked with ice, the upper and lower channels to the fridge are blocked with ice and obviously therefore no0 cold air is going the fridge, I have de-frosted the freezer and put back together and everything works great for 2 weeks when the same thing accurs. My settings for both fridge and freezer are on the lowest possible, but the wife does fill the freezer with too much food! I guess I need an expert in!!
Jun 16, 2010 | Admiral 26 cu. ft. Side-By-Side...
Water leaking from the bottom of frig
Your  deforst drain is clogged.  Every 12 hours or so your fridge does a deforst cycle.  It melts all of the ice built up on the evap coils.  There is a drain at the back of the fridge that goes to a pan by the compressor where the heat from the compressor and the condensor coils evaporates it.  Take the back panel off of the freezer compartment and plunge out that hole.  You will most likely have a build up of ice over the top of the drain.
May 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
My Maytag refridgerator is leaking from the filter and in the back. It sat in the garage for one year not being used. Because 6 months after the warrenty was over the relay switch melted, and caught on...
If it sat a year in the garage are you in a climate that freezes in the winter time? There is water left in the lines and the filter after you disconnect the fridge unless you blow it all out, so it could have freezed and expanded and cracked a piece. If freezing is not a possibility then i would get a new filter if you havent already, the o-rings on the filter could have dried out from being in a hot garage in the summer and caused a leak. Its a pretty simple system though, the water line comes in from the back to the filter housing and then from there it goes to the water in the door and the ice maker. Another possibility is a line could have got snagged and pulled on when moving it, so check all the connections under the fridge for the water lines. Put some paper towels down under the fridge and have someone dispense water from the door and watch it with a flashlight and see if you can find the water leak, the paper towels will help by showing where they get wet and give you an area to investigate further.
Jan 11, 2018 | Maytag MSD2756G Side by Side Refrigerator
Maytag side by side fridge...water dispenser problem
If the water is visible in the front, more than likely the hose has become disconnected from the door, if you look at the lower left hand corner you should see the hose come from underneath the machine and attach to the door via a plastic quick connect, it is just a push lock connection. You may have to pull of the toe kick and the left hand end cap depending on the model to see this.
Jun 15, 2009 | Maytag MFI2568AE Side by Side French Door...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Refrigerators Logo
80 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
