Question about RIM BlackBerry Pearl 8100
I have a B & D battery operated hand drill. The batteries will not recharge. The light on the recharge does not go on when recharging. 18V is what is imprinted on the recharging part that the batteries slide into. How do I get this repaired/replaced. michaelsiegel@kw.com
I called a B & D service center.
mjs
Posted on Jul 26, 2008
18 v lithium-ion battery will not charge
The batteries were discharged too low. A lithium battery should be recharged as soon as you see a loss of power.
Jan 12, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi batteries P103 (2) or P104
The physical differences between two models of Ryobi batteries is:
- The P103 (Part Number 130429008) is a 1.5 Amp/Hour (a measure of how long a battery lasts on a charge) battery. If totally discharged it takes about 15-20 minutes to charge back to full. It is lighter than the P104 because it has half the cells inside. Lighter, quicker to recharge, quicker to discharge, shorter lifespan.
- The P104 (Part Number 130429017) is a 3.0 Amp/Hour battery. It takes about 30-35 minutes to charge it to full if fully discharged. Slightly heavier, longer time to discharge & recharge, longer lifespan.
Considerations:
- No difference between batteries in the performance of your tools.
- The number of times you discharge and recharge a battery determines a batteries lifespan. That's why most manuals will tell you to fully discharge a battery before putting it on a charger.
- If you only have one battery you cannot use your tools while it is recharging. On big projects you have to have two batteries.
- The weight difference between batteries is negligable unless you are working with the tool in your hand for extended periods.
Mar 04, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
Revive drill driver battery packs
Rechargeable batteries do have a lifespan, they won't recharge forever. If you have fully discharged the batteries then fully recharged them and they still don't have full power or they only last a couple minutes then they are done. If they won't charge or the charger shows them as defective, the only fix is to replace them.
Jan 29, 2012 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I have an 18V cordless drill/driver. When I tried to recharged the battery, the battery stayed dead. The red light was on while recharging. The charger stand has red and green LED indicators but only the...
Chargers will out last batteries by a long time.You will need to get a new battery. Black & Decker is a cheap household brand and does not hold up for long periods of time. I have better brands and buy several new batteries every year.
May 30, 2011 | Black & Decker 18V Cordless Drill/Driver
Coleman 18v drill CTP 8129 number 9408 label underside drill. Probably 30 hours total usage over 2 years. Appeared not to hold charge after 18 months - had to recharge before every use on a 1 week...
These batteries never last very long. That model of drill is no longer made but I did find some refurbished batteries on EBAY. However, with EBAY you get what you get. Personally, I would never buy a refurbished battery and besides, they are way overpriced for a refurb. Sorry my friend but you would be better off just buying a name brand drill with Ni-cAD batteries (18V or 24V are the most common). I have a 24V DeWalt that I love and replacement batteries are cheap.
Aug 01, 2017 | Coleman Drills
Need to know what terminals to conncect a 12v charging system to a Dewalt 18v battery in order to recharge it. I know it is a three prong system and I am assuming that the small center ground is used for...
I do not recommend connecting anything but the factor charger to the battery. No 12v will not not charge an 18v battery.
They can BLOW UP if you apply too much current.
The correct charger can be found cheap. Look on craigs list under tools.
Good Luck
Feb 01, 2011 | Dewalt Drills
Why does my battery not charge when put on the charger
Rechargeable batteries have a limited life determined by how many times they've been discharged & recharged and how old they are. On the charger there are lights and a chart to let you know what's going on with your battery. If it indicated the battery is defective, the charger won't even try to charge the battery and it needs to be replaced. If it goes through a recharge cycle and then lasts for a couple minutes or not at all the battery is used up and needs to be replaced. If none of the lights on your charger are working the problem may be the charger. The only way to test that is to have someone else with an LXT kit try to recharge your battery.
Jan 03, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I get a green and yellow light on the Ryobi 18v charger and the batteries don't recharge. Does this mean the charger is now bad? Thanks for any help. Dan
This usually indicates that one or more of the rechargeable C batteries is not recharging. The batteries are standard rechargeable C batteries but the terminals are spot welded and are very hard to separate. There are 15 rechargeable C batteries in the Ryobi 18v battery pack. A battery tester will show which battery(s) needs replacing. There are refurbishing centers (Google search) but they will replace all the batteries and usually upgrade the OEM 1500 mah batteries with 2100 mah, or higher, batteries.
Jul 07, 2010 | Ryobi Multi-Volt Battery Charger
Reset DeWalt battiers using a mig weilder
I never heard of such a thing- messing with rechargeable batteries with home remedies can result in the battery melting or possibly exploding. Be very careful how you treat any rechargeable battery. Try rechargeing it twice in a row, letting it cool serveral minutes between charging. Heat is the death of rechargeable batteries.
Jun 22, 2009 | Drills
RIM BlackBerry  Pearl  8100 Logo
60 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
