Question about Epson Stylus Photo 830 InkJet Printer
Printer not used for long time. no manual available
Printing starts but paper is not picked by printer
  • MAHESHKUMARC Nov 10, 2008
    IN MY PRINTER IF I INSERT A PAPER IT COME OUTSIDE IMMEDIATELY IT IS NOT PRINTING I HAVE ALREADY INSTALLED DRIVER. I DO NOT HAVE USER MANUAL OR SERVICE MANUAL
  • Matt Konyn May 11, 2010
    Could you explain that a bit more?
  • 353 Answers
It sounds like your Automatic Sheet Feeder (ASF) has a problem, I suspect either due to something broken, or not re-assembled properly (assuming your printer has been dis-assembled previously). If you do not feel up to dis-assembling the printer (the service manual is available very cheaply) to have a look, sell it on e-bay for what you can get!
Posted on Jan 31, 2009
How can i fix my HP Deskjet F4280 printer, it wont pick paper for printing
Uninstall the printer, delete drivers, look if new drivers are available for it and reintall the printer.
If problem continues my guess is that your printer is defective.
Printers are made of chep plastic materials and after some use parts get worn out and break down. HP has a so called repair kit available for repair service. If your printer won't pick papaer, quite probably some of these partss is damaged. If you don't know how to repair printers aand dont have access to parts, take it to a repair service.
Oct 12, 2015 | HP DeskJet F4280 All In One Printer InkJet
I have a Laserjet p4014dn printer. it warms normally but once it picks up paper, it jams. i have dried clearing jam several times but on starting to print it jams
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam..
2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage..
3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
Aug 31, 2012 | HP P4014DN Laserjet Printer
JAM IN PRINT PAPER PATH
It could be the papar problems ,checks and buy a recommended and quality paper .
Mar 09, 2012 | HP Laserjet Cp2025n Printer
It does not pick up paper to align the cartridges, not will it print anything.
This model has a fairly common problem with the paper feed. If it appears that it tries to pick up paper but fails, then most likely there is a broken part.
Parts are not available for HP ink printers.. it's probably time for a new printer.
Sep 20, 2010 | HP 7210 OfficeJet All-In-One Printer
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
Not picking up paper
Most new printers and copiers will attempt to feed paper several times before failing and giving a jam condition. It sounds like that is what is happening to your printer.
Your tray rollers may be dirty. Remove the tray and use a clean cloth with mild detergent to clean the rubber rollers. Do not use alcohol this will dry the rollers out. If problem continues replace the tray rollers.
May 18, 2010 | Samsung CLP 300 Laser Printer
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Paper stuck - Samsung ML2010
Clean the roller with 409/simple green or water. Use a cloth not paper towel. NO alcohol. Rub it up good and it should start feeding. steven 818-888-0006
Apr 27, 2010 | Samsung ML 2010 Laser Printer
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
steps:
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
Epson Stylus Photo 830 InkJet Printer Logo
106 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
