I have E-machine Model W6409. Loaded Windows Vista, did not like. Went back to XP Media Center Program, now I have no output from speakers, can you help?
    Genius:
  • 3,422 Answers
You will have to install the sound drivers first so that you can hear the output from your speakers.
Posted on Jul 25, 2008
  • Priya darshan Jul 25, 2008
    Please right click on MY COMPUTER select PROPERTIES then select the HARDWARE tab and click on DEVICE MANAGER.
    Now in device manager double click on SOUND,VIDEO...and then under that you will see your sound drivers with a yellow question mark next to it.Just double click on that and go to driver tab and select install drivers if you can click or else just click on update drivers and let it search automatically and install.
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Inter Audio Sudio Controller states Sonic Focus
Try reinstalling your audio drivers, or use system restore to undo the update if yo are sure of that.
Reinstalling the proper drivers should generally fix it though.
In case you don't have them anymore, try the manufacturer's website or a driver finder program.
Dec 14, 2009 | Intel ESS ES1868F Sound Card
I went from vista to windows xp I had speakers working on vista and when I went to windows xp they didn't work
If the computer hardware was "designed for Vista", it usually means that device-drivers for audio/video/network components for Windows XP will not be available. Switch back to Vista, or upgrade to Windows 7.
Nov 14, 2009 | Compaq Computers & Internet
Windows XP, error message!! Media Center TV don't work now, etc.. Error message pops up all the time!!! After I loaded a RipTiger software, had to unistall but still left with this pop up message!!! Media...
Try going into Control Panel, Add/Remove Programs, click on the Media Center software, if listed, and see if it gives a choice to Change and/or Repair. You'll probably need your Windows CD if/when it prompts for it.
Oct 28, 2009 | Microsoft Windows XP Media Center Edition...
Is protools compactable with windows xp media center
Yes, it is currently supported all the way up to Vista x64. For future reference any Windows XP supported program will work fine with Media Center. Enjoy!
Jan 31, 2009 | Computers & Internet
Tv tuner problems only with Vista Media Center
THE LANGUAGE OR PROGRAM IS ADVANCE LANGUAGE WRITEN IN A DIFFERENT CODE, WINDOWS XP CODE IS DIFFERENT CODE THAN VISTA 32 - 64 BIT SYSTEM, THE 32BIT IS NOT TOTALLY COMPATABLE THERE IS SOME ITEMS THAT MITE WORK BUT YOU ARE DEFEETING THE PURPOSE WHY YOU WENT TO VISTA, OPEN LOTS OF WINDOWS APPLICATION AND RUN THEM ALL AT THE SAME TIME WITHOUT WAITING ONE PROGRAM TO FINISH BEFORE YOU CAN START ANOTHER ONE, MULTIPLEXING. I HOPE THAT HELPED YOU, NOW WE HAVE WINDOWS7 OUT BETTER THAN VISTA
ROD
Jan 11, 2009 | Pinnacle PCTV HD Pro Stick USB 2.0 TV...
Xbox 360-computer?
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
  1. Start Media Center.
  2. On the Settings menu, click General.
  3. Scroll down, and then click About Media Center.
  4. Click Software Version
    The version number of Media Center you are running is displayed.
To determine the version of Windows XP that you are running, follow these steps:
  1. On the Start menu, right-click My Computer, and then click Properties.
  2. On the General tab, under System, look for the version of Windows that you are running.
Oct 05, 2008 | Microsoft Xbox 360 Console
Pc will not see tuner
no but that is way to low in vista need leats 2 gb ok
Feb 11, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
David Payne
David Payne
