Question about Dell 1600n All-In-One Laser Printer
Scanner doesn't work - Dell 1600n All-In-One Laser Printer
  • 1 more comment
  • Anonymous Jul 28, 2008
    yeppa
  • vipavion Jul 28, 2008
    Same problem
  • rosemarylint Nov 11, 2008
    I place the paper I want to scan face down, press "Start Scan" Menu comes up "Scan and Reprint" "Scan to Memory Device". Later does not work. Option "Scan to Microsoft Word" does not appear anymore so I can't scan anything. No solution in manual. Email www.rosemarylintner@verizon.net Thank you. Rosemary
First of all, the pages to be scanned should be face up not face down......
Posted on Dec 02, 2008
MC 9190 LongRange scanner
It looks like the backup-battery is empty
May 29, 2013 | Zebra Symbol Technologies MC909X-G Series...
I have HP SCANNER G2410 ."tak tak" sound on
Just a guess, may be you have not unlocked the scanner.
On the bottom side there is lock for transporting the scanner. Turn the scanner upside down and check. Put it into the unlock position.
As I said it is just a guess. If this doesn't work, let me know.
Sep 23, 2011 | HP ScanJet 2400 Flatbed Scanner
I installed a printer on my PC and the scanner does not work. Should i install the scanner aswell?
Do you have the combo printer that comes with scanner and printer in one machine? If you do, then one installation should work the device as the computer will recognize it as one. If that's what you have, and the scanner still doesn't work, return the machine and ask for a new one.
If you have separate scanner and printer machines, then you should have two installation discs as each should have its own. You will need to install the scanner if this is the case.
Hope this helps.
Aug 30, 2011 | Office Equipment & Supplies
I have an hp psc 750 and the scanner doesn't work or won't work I need help to get it working,
you have to open the top cover and clean the scanner mirrors in the scanner unit.
Aug 04, 2011 | HP Office Equipment & Supplies
I have updated my computer to a Windows 7 version and my PrimaScan Colorado 2600u driver does not seem to be compatible
Hello, I've looked around on the website and there doesn't seem to be a driver for this device to work on Windows 7. It doesn't support this operating system, sorry.
You can either downgrade to Windows XP or get a new barcode scanner.
Jul 09, 2011 | Visioneer PrimaScan Colorado 2600u Flatbed...
My officejet 6210xi all in one, the scanner doesn;t work it's says need software or driver for work but web hp says the driver for this windows 7 install automatically, the printer and copier work good...
Windows 7 will just have the printer drivers for this unit by default. If you want to be able to scan, you should install the full version of the drivers which is available from the HP website. Just search for your model number, select the operating system, download and install.
Jun 17, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Im trying to scan a document but its saying error code 2106. i have it hooked up through wireless
Try these things:
1. place a doc to scan in the scanner. Close the lid and hit MENU, COPY document, START.
If that doesn't work you'll need to contact kodak. If it does then try this next:
2. Check for ADMINISTRATOR rights.
  1. RIGHT CLICK on the kodak icon and select Properties > Compatibility tab > Run this program as an administrator
  2. Select RUN AS ADMINISTRATOR
  3. click APPLY
  4. click OK
Then try scanning again. If it still doesn't work then-
Reload the driver:
  1. select Start > Run.
  2. Type %windir%, then click OK.
  3. Double-click twain_32.
  4. Right-click Kodak, then select Delete.
  5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to (cd drive: > printer > scanner.
    Double-click aioscannr.msi, then follow the instructions to remove it
  6. Then go to cd drive: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
  7. Open Home Center Software
  8. Select Scan Documents and Pictures.
  9. Scan a document
If it still doesn't work then you'll need to take it in for service.
Jun 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Canoscan Lide 30 compatibility with Windows 7.
There are no official drivers for CanoScan Lide 30 for Windows XP, so your problem is obvious. I suggest you sending an e-mail at Canon including details about your scanner (date purchased, serial number in text form or scanned) asking them to develop driver set as this model is very trade and at shops since 2006 or 2007.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 27, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
?Scanner failure? error message
Usually this type of error message pops up when the scanner lamp isn?t warming up properly. This is what you should do: 1. Check if the lamp is on. 2. Unplug the scanner?s power supply and plug it back in. Try connecting it diretly to the wall. 3. If that doesn?t work: a. Unplug the unit?s power supply. b. Press ?cancel? and left arrow while reconnecting the unit. c. Release the buttons when the printer starts up. 4. Try scanning again. 5. If it doesn?t work, have it serviced.
Feb 22, 2006 | HP PSC 750 All-In-One InkJet Printer
Dell 1600n All-In-One Laser Printer Logo
93 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
