Question about Visioneer One Touch 7600 USB
Visioneer One Touch 8700 USB Scanner lock mechanism problems
Hello....I am unable to get my Visioneer OneTouch 8700 USB Scanner to work properly...it is a recent gift and brand new...I keep getting a "lock error" message indicating the scanner is locked underneath when my scanner is NOT locked,,,,I downloaded the latest driver from the Visioneer website...i am running Windows XP, Service Pack 3...I even popped the glass lid and physically moved the scan bar several times back and forth across the length of the scanner to make sure it wasn't "locked" or just "stuck"---it does move freely...upon replacing the glass lid and reconnecting the scanner to my computer i get the same "lock error" message problem,,,can u please help advise what I can do to resolve the matter,,,,it seems this is a common problem with Visioneer low end scanners,,,,after contacting Visioneer Knowledge Portal, I have checked everything that Visioneer advised in response (i.e., correct power supply connection, uodated driver, minimum RAM)....is this device simply unfixable?.....if so, why would Visioneer market such a deceptive, cheap product?....any advice you can give would be appreciated,,,I am at: pintobuck@yahoo.com
I thank you in advance.
Tim
  • Anonymous Dec 15, 2008
    I've got the same problem. Keep getting error message that scanner is "locked", but it is NOT!
Not sure if your problem is the same as mine, but I encountered the same error and only to find that I plugged in a wrong power adapter so it didn't have enough power to advance the scanner head (My moving caused this mixup). Check your power adapter OUTPUT is 12V (or whatever is specified on the scanner itself, usually found on the label on the bottom or rear).
Posted on Sep 10, 2008
Need a driver for Visioneer OneTouch 8700 Flatbed Scanner
The drivers for supported OS versions are available here: http://support.visioneer.com/products/8700/downloads.asp . The supported OS versions are: Windows XP SP 1 / 2000 Professional / Me / 98SE and the additional software that was bundled on the CD is not included.
If you have a different Microsoft OS, you can check the Microsoft compatibility center for either Vidat or Win7. A check of the Win7 compatibility Center http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx showed some Visioneer OneTouch scanners work with Win7. However, the 8700F is not in the list.
I hope this helps.
(Dual boot with XP or a virtual computer with an older valid OS version will work. The Win7 Pro and Ultimate let you use Virtual PC and XP mode to run an XP virtual computer for free.)
Jan 03, 2011 | Visioneer OneTouch 8700 Flatbed Scanner
I had a new install of windows xp (with service pack 3)on my computer and am now trying to install my visioneer one touch 8700 scanner. Is there a problem with the driver and the xp service pack 2? How can...
You will have to uninstall the device. Delete any files it created on the drive as part of the install. (Not things you'[ve scanned, just program files) then disconnect the scanner. Reattach the scanner in a different USB port (different SCSI id if your using SCSI) and let Windows re-detect the scanner.
This time don't run the setup from the driver CD. Instead let Windows find the scanner and try and set it up on it's own, if it prompts you for a driver, point it to the INF file in the installer directory. If it doesn't, let it use the one it chooses.
After installing in this way you should be able to use the scanner as a TWAIN source from any application.
Apr 19, 2010 | Visioneer OneTouch 8700 Flatbed Scanner
Need drivers for windows xp pro 64
The XP driver is available at:
There is no indication of 64-bit or 32-bit support. However, the driver is not guaranteed to work with XP SP2 (only tested with SP1). This suggests that SP3 is also not tested.
I wish that I could be of more help.
Mar 25, 2010 | Visioneer OneTouch 8700 Flatbed Scanner
I lost my scanner icon from taskbar scanner will not work properl
Right click on the taskbar go to properties then click on customize button and select the appropriate icon u want.
May 01, 2009 | Office Equipment & Supplies
Hi, i have a problem with my scanner visioneer one touch 5300 usb scanner i have windows xp installed on my pc and i can't find the drivers for xp of the scanner where can i find the drivers and download...
I have a GOOD, WORKING driver for the Visioneer 5300 USB scanner, for Windows XP and Vista.
I include very detailed install instructions that I have personally wrote and tested. Send me an e-mail to artb126@yahoo.com. Subject Line - 5300 USB driver
Dec 04, 2008 | Visioneer OneTouch 5300 Flatbed Scanner
Windows X-P
Here is the link of HOW TO:
http://www.visioneer-europe.com/support/faqs/15.htm
Dec 29, 2007 | Visioneer OneTouch 7600 Flatbed Scanner
522 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Level 1 Expert
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
