Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
XBOX NETWORK ADAPTER
MY WIRLESS NETWORK XBOX ADAPTER IS STAYING ON RED LIGHT AND SAYING IT IS DISCONNECTED. MY ROUTER SEEMS TO BE WORKING FINE SO WHAT ELSE DO I NEED TO DO?
  • 1 more comment
  • xiller Jul 25, 2008
    my adapter doesnt even turn on when my console is on when i un plug it then plug it back in it stays red. and it wont sign me into xbox live please help
  • A Dizzle Aug 21, 2008
    my adapter was working fine and out of nowhere it says its not connected. the light is on and the router is working fine
  • Jman-cool May 11, 2010
    When you go to network settings there is no wireless mode plz tell me if that was on the non nlx
This happened to me to it seems to be very common and xbox support knows nothing PS3 and WII RULE
Posted on Aug 05, 2008
I had that problem too and i just went to the network settings and clicked on wireless mode and then it had my router info there so i clicked on it and now its working perfect
Posted on Aug 06, 2008
My 360 wifi adapter has a steady red light the xbox picked up the signal from my wireless router but I try to connect it says there is a problem with your connection. What can I do? The wireless router is...
Did it ask you to enter a security or web key. most systems require that to verify a secure network. You can find the key on the back or bottom of the router.
Jan 28, 2011 | Microsoft Wireless Network Adapter Xbox...
How can i get xbox live wirless working after buying the adapter. I have bought the xbox wirless adapter and i am having trouble getting wirless.
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :).
Dec 31, 2009 | Microsoft Wireless Network Adapter Xbox...
My xbox 360 wireless adapter stays red and wont turn to green, my router and modem seem to be working
Switch them off and then on in the following order:
modem, router, computer. Make sure adapter is switched on!
Nov 26, 2009 | Microsoft Wireless Network Adapter Xbox...
My wireless adapter for my xbox 360 stays on red light
You can try fixing this using Xbox360 repair guide that covers almost all xbox 360 problems, you can get a copy from here
http://xbox360repairguide.com
Jul 10, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless adapter problem
The turning red means that it cannot connect to your network. If you are having trouble connecting it to your network then you are able to enter the details in manually. The WEP key should be on your router. Try entering this. Hope it helps.
Jan 19, 2009 | Microsoft Wireless Network Adapter Xbox...
I just bought wirless adaptor for my sons 360 I have a sky router which works my daughters lap top fine. can u tell me how to connect xbox to wireless system as there were no instruction with the adaptor...
Ok, heres a list on what to do. -With the console off, connect the adapter into the console via USB and clip it to the console with the clips provided.  -Power on the console and go to network settings.  -Find the section that says "find wireless networks" -Select yours and test the xbox live connection -FOR MORE HELP CALL 1-800-4MY-XBOX
Dec 30, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 wireless networking adapter solid red light
make sure its pluged in properly then scan for networks if it does not find any networks make sure that your ip address is set to auto then tipe in your WPA key that sould work if it doesnt send me an email to reece16cc@hotmail.co.uk and i will walk you trough the steps till you can conect and PLZ RATE SOLUTION TANKS
Nov 17, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 wireless adaptor
the only solution is to buy a new adapter or find a local electronics store to fix it for you!
Sep 07, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox network adapter red light flash
there could be a problem with the adapter, a faulty connection in the cable or something else, or it could be your router. The adapter only works with type A B & G routers. I know a few people who have N routers and it wont work with them. 1st check to see if your router is a typer A B or G then make sure that the wireless signal is set to a frequency that the receiver can find usually channel 6 or so. 2nd, try disconnecting the adapter rebooting the console, then reconnecting it with the power off. if all else fails, then it might be that it is a bad adapter. Also if you use a wireless encryption, make sure that you have the key entered in the wireless setting on your console, and try using a WEP key as it is easier for the adapter to read then WPA.
Jul 01, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 wireless adapter
This happened to me and I disconnected it and plugged it in the top USB in the front of the console.It worked!
Jun 13, 2008 | Microsoft Wireless Network Adapter Xbox...
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
366 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
