If you have a gas or oil furnace then the limit control is probably bad. If you have electric heat or a heat pump then the sequencer is probably bad. But first make sure the thermostat is not set to "FAN". The thermostat must be set to "AUTO". Many systems have a time delay on the fan to capture the remaining heat after it completes a heating cycle. Usually several minutes.
