Question about Linksys Wireless-G WRT54G Router
I am trying to register my product, the linksys wireless broadband router. When asked for a e-mail address they say they don't have it. I don't understand I am trying to register
  • 1,689 Answers
Bernief, well it could be a minor error on the site, it happens when they upgrade their website, best move, call 1-800-546-5797 then look for the customer service option or an RMA option, they will register it for you, good luck
for more theck info, visit my article - VooDooMoX
Posted on Jul 25, 2008
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router Wireless G-Broadband Router support b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router
Mar 27, 2013 | Linksys Wireless-G Broadband Router
How do I configure my tablets IP address to my router to get online?
It's the other way around. The router provides the IP. Check the router and make sure DHCP is enabled.
Login via web browser.
User: (none / blank)
Password: admin
Oct 09, 2012 | Linksys Wireless-G Broadband Router
Where can i find HEP code for linksys router?
It's known as a WEP Code:
Open up Internet Explorer and type in the address bar "", do not use the "http://www.".
On the Linksys website, click on Wireless, then Wireless Security, then look for the WEP key. If it asks you for a password, it should be "admin".
Jan 21, 2011 | Linksys Wireless-G Broadband Router
Linksys router connects and says it has an excellent signal but will not aquire an address please help
Try a hardwire computer and get into the setup page of the router by typing on your browser . Make sure you have changed the SSID or the network name of your router to your choice. Check if you have security set. If you have one make sure they match your computer.
Nov 11, 2009 | Linksys Wireless-G Broadband Router
I want to security enable my wireless internet
What you are asking about is called Wep security and is available in your router control panel ("http://" whatever your router is set to) then go to wireless>security and setup a Wep key. You can also go to this web page for more info:
Good Luck...
Mar 26, 2009 | Linksys WRT54G Wireless-G Broadband Router...
Password for the Linksys Wireless Router
Power down the linksys and on the back is a reset button push it. The ones i have installed dont need a pass word or key,if it is asking you try the info you used from your internet provider ( e-mail address or access #s)Also try skipping this step and see if it will let you go on to the next part,Lynksys advisor has major issuses with it I dumped it from all the pcs I installed.
Jan 26, 2009 | Linksys Wireless-G Broadband Router
Cant get on wireless forgot ip for linksys wrt54g
make sure that modem is connected to the linksys, and cords are properly seated.
if cords are seated correctly, hard wire computer to linksys first.
second, access the linksys software thru on the address bar on internet explorer browser.
third,if you will see pop-up box asking for username and password.username must be left blank and password must be set to admin.
forth,inside the linksys software try to access wireless settings.
Dec 04, 2008 | Linksys Wireless-G Broadband Router
How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
Nov 07, 2008 | Linksys Wireless-G WRT54G Router
Installation broadband router linksys WRT54G v5
In your internet explorer address bar, type in the ip address of and see if it asks you for a password.
If that isn't it, try
The default password is admin. No username.
Also, go to and they have free chat support and can walk you through this issue.
Apr 30, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Linksys Wireless-G WRT54G Router Logo
42 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
