Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Door handle came loose
I need to find a way to open up the space between the shelves and outer door to re-attach the handle. How can you do this?
  • Frigidaire Master
  • 4,654 Answers
Download the PDF look at picture confirm this is your refrigerator and and read the Q&A on second link This will help you solve the problem, Let me know, Thanks, Sea Breeze
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
http://www.applianceaid.com/refrigerator.html#freezing
Posted on Feb 01, 2009
Door handle has come loose
I think you can just use a quick dry super adhesive glue to hold the handle in place.
Jul 28, 2008 | Frigidaire 14.1 cu. ft. / 399 liter...
Freezer door does not have the vacuum suction that it did have
Check the door is square to the frame and no shelves are sticking out stopping the door from closing properly. The seal should be magnetic and stick to the frame quite well.Check no metal strips have come off so the magnetic seal isn't attaching to the frame
May 20, 2012 | Frigidaire 20 cu. ft. / 566 liter Upright...
Frost build up especially on top shelf all other shelves except one gets a 3 inch layer of ice in approx 4 months. The freezer is kept in a mod temp basement room and the freezer door is opened less than...
Things you can do to cut down on frost.
1.make sure all seals fit flush to frame.
2.use a thermometer and set freezer to -18c(beef will keep upto 12months).
3.wrap all food as airtight as poss.
3.do not overfill,leave space for air flow through drawers/shelves.
4.defrost every 2/3 months in humid conditions using clorine bleach to clean interior,and dry thoroughly.(leave door open to dissipate clorine gas.)
Aug 18, 2010 | Woods Upright Freezer V1613RW3
Have an Amana Side by side refrig/freezer (model ACD2234HRS) that has a loose refrig door handle. How do you get access to tighten the door handle screws?
i believe there are plastic coverings that just pop off. they are located at the hinge,you will need to fully open the doors to get to them.
Sep 20, 2009 | Freezers
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Loose handle
yes , on most freezers the door inner panel liner needs to be removed , that will sometimes require the removal of the door gasket that may be old to the point where it to needs replacing. then finally you can get to the back side of the door and snug up the screws that hold the handle from the back. usually fine thread screws. be sure to apply loc tite and snug up good , we don't want to do this again any time soon. you can take a chance and try pulling out the handle and cutting the screws and then drill the hole in the handle out to where you see a hole in the side of the handle from the front, then counter sink the hole and use a drill screw or a small toggle bolt to resecure the handle . no real wires or refigeration tubes in the door, so its an option. good luck
Nov 24, 2008 | Freezers
Maytag upright freezer model MQU1556AEW
I experienced the same problem last week with my freezer. Apparently the change in temperature during defrosting allows the blade locking mechanism to slide on the motor shaft during the spinning operation. The blade pulls itself along the shaft until it comes in contact with the motor mounting bolt. If your freezer just stops getting super cold, but remains cool and you don't hear the fan spinning, remove the inside back panel and check the fan blades for freedom of movement. I almost disposed of the freezer this past week but decided to make one last check of the mechanisms.
Sep 22, 2008 | Freezers
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
114 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
