If it was an electric oven, it would likely be the heating element itself. But since it is gas, we have to look elsewhere.
The most likely culprit would be the temperature sensor inside the oven, & that is not registering the temperature correctly. It is saying that it is a different temperature than the oven really is, so that you cannot get it to go higher. Typically this would not be a user replacable part. If you can find your manual for the range, you would be able to tell for sure if it is user replaceable or not. If you need to call for service, GE has a reasonable price for their service calls - and they can also check the range and oven nozzles etc to make sure they are functioning correctly. Or put another way, you can have them do a preventative maintenance check on the whole thing while they are there. Be sure to tell them what you know it is doing ahead of time as well as the model and serial numbers, so they can have at least some of the parts with them.
Good luck.
Was this helpful?
Yes
No
Popular Solutions for GE Profile Spectra JGBP90 Gas
The tubing from the knobs to the burner cracked! I was cooking and there was this loud boom and...
(More)
The tubing from the knobs to the burner cracked! I was cooking and there was this loud boom and flames. I immediately turned it off and checked under the top and found the tubing cracked and there was another one cracked too! I need replacement parts and to make you all aware of this danger.
Stove gas turns on and off when preheating. Takes forever to heat oven to desired temp. What do...
(More)
Stove gas turns on and off when preheating. Takes forever to heat oven to desired temp. What do I need to adjust to keep the gas flowing longer to heat the oven?
my ge profile gas locked door is blimking after I perform a self clean for the 1st time and I tried...
(More)
my ge profile gas locked door is blimking after I perform a self clean for the 1st time and I tried the troubleshoot online still not working. what should I do?
