Just had a new indesit iwme12 fitted yesterday and it won't work! doesn't seem to be any water going into machine, checked that water is on. help!
  • Anonymous Mar 14, 2014
    I can't seem able to do spin only on my washing machine
  • Anonymous Mar 16, 2014
    wont turn on
  • 70 Answers
How did you check water is on? with some tap fittings the handle is in the on position but the valve does not open loosen the pipe at the point it enters the washer if you get wet theres water geting to the machine then check it is swiched on and the fuse in the plug aint blow
Posted on Jul 25, 2008
  • anth1 Aug 27, 2008
    please give me a rating for this thankyou
Indesit Iwme12 fills with water then nothing else, i took it apart then got it spinning but same has happened again??
Is the belt badly worn? When you "got it spinning", did you have to help the motor to start? If so... that motor is probably at the end of its life. If not, what did you do to get it spinning?
Aug 08, 2014 | Washing Machines
Indesit iwme12 fills with clean water when not running
sounds like a faulty valve. it maybe weeping, leaking water in.
Jun 20, 2013 | Washing Machines
How to rid of mould on and underneath rubber seal by door as making washing smell musty,model is INDESIT IWME12, thanks
when coming across this problemn i just tell my customers to put the machine on its hottest wash with a capful of bleach instead of powder this works ok good luck.
Jun 07, 2011 | Indesit Washing Machines
How do i remove the soap drawer from an intergrated indesit iwme12 1200 spin 5.5kg washing machine please?
Hi, I had the same problem, Open the drawer fully by pushing the right hand side in to release.
With the tray fully open, hold the white front bit steady and pull drawer bit, hard towards you. Quite a lot of force is needed.
Its held in by a plastic clip that clips onto the hinge part of the front cover. Hope this helps took me 3 months to take the courage to pull hard enough.
Oct 11, 2009 | Indesit WA 115 Front Load Washer
How to fit new door seal on Indesit W103 washing machine
this is not an easy job,go online and down load a copy of the machines manual even check out indesits web page.adrian
Feb 23, 2009 | Indesit W 123 Front Load Washer
Dishwaher not working
switch on water appears to run in after a few minutes second and forth green lught comes on and machine stops it is a IDL500 indesit machine
Jan 09, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
My Indesit Washing machine doesn't seem to start?
Most likely water has short-circuited your controls; you need a specialist here.
Apr 09, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
