Question about Zanussi 24 in. DE6965 Built-in Dishwasher
Potscrubber 700 connector to faucet
I was given a Potscrubber 700 that is missing the connector that hooks onto the faucet. Is there anyway to find a parts list to see if I can just get a new hose assembly or the quick connect?
How do I uninstall my dishwasher?
Turn off ALL power and water. Move machine until you can see the hoses and power point. Unplug power and switch off, disconnect hoses and turn off any taps/faucets. Fully remove machine. Turn power and water for residence back on.
Aug 11, 2014 | GE Dishwashers
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
Looking for dishwasher manual for Model Number GSC700X01AD. GE Potscrubber 700
is this the manual your looking for if you have any further questions or feel that this is not the right manual message me back and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to help others in similar situations in the future Thanks Rick
Feb 13, 2011 | Dishwashers
Water leaking from the faucet onto the countertop.
Check out this web site and it looks like it should be a o ring at the base, anyway I hope this will be helpful.
It has a breakdown of faucet internal parts.
Jun 04, 2010 | Rohl A3608LMPN Single Lever Country...
My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Dec 07, 2009 | Dishwashers
Faucet connector
If I am reading this correctly you want to connect washer to the faucet inputs. This requires washer hose kit at any hardware store. Kit has two hoses,<simular to garden hose> they have double end that will connect to both washer and faucet.Make sure when hooking up you hook cold to cold and hot to hot,< washer has C and H to know which is which.
Apr 25, 2009 | Washing Machines
GE Potscrubber 720 attachment
i got mine from the local Home Depot. its called a "bubble stream Large Snap Fitting"
Nov 22, 2008 | GE 24 in. GSD2600GBB Built-in Dishwasher
Never had a portable, put connector on tap and it blasts off when turn on water
I am assuming that you have the appropriate adapter on your faucet.
You are not actually getting the connector attached to the faucet.
Pull down on the locking collar while lifting the hose connector onto the faucet adapter.
When the connector snaps into place, release the locking
Turn the hot water on slowly until it is all the way on.
Sep 16, 2008 | Dishwashers
GE potscrubber 700
upc leaks when dishwasher is emptying
May 12, 2008 | GE Dishwashers
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
