Question about Frigidaire Affinity ATF7000ES Front Load Washer
Frigidaire Affinity ATF8000ES?
I just purchased the Frigidaire Affinity ATF8000ES? front loader less than a week. Water stays in the soap/bleach/softner drawer after the load is complete. I need to dump the water out (in a different room) before refilling the compartments. I have talked to other people w/front loader without this problem. A service person and said that this is normal. Should I send the whole washer back and get a new one?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Water is not draining from the softener/bleach
Here is a tip that I wrote about what I found out about the fabric softener notdispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going intowasher
heatman101
Posted on Oct 09, 2010
Why does my frigidaire affinity smell
clean it by using 5 cups bleach fill soap cup put rest in tub wash in hot water long cycle run another or 2 after to make sure bleach is gone
Jun 07, 2014 | Frigidaire Affinity ATF7000E Front Load...
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Bleach & Fabric softner tray not working.
Remove the drawer by pushing the tab at the top of the drawer and pull it out and check for an obstruction. They regualarly plug up with gummy fabric softenener. Try washing out with hot water and reinstall
Apr 04, 2010 | Frigidaire GLTF1670A Front Load Washer
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
Why does my detergent drawer always hold water in the fabric softner and Bleach drawers
pull the drawer out and give it a good cleaning in warm water/also take a look into the hole you pulled it out off and make sure it not blocked with mould etc.adrian.;;;;;;
Nov 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Bleach/Fabric softner dispenser full of water after wash
I cannot help you solve your problem with your Frigidaire, however DO NOT buy an LG washer unless you happen to be intimately involved with an LG employee!!
I purchase a $1200 LG washer 3 years ago. Until this year it worked very well. Then the bearing in the stator motor blew. This, mind you, is *still* under warrantee but I have been unable, even with the dubious help of LG, to get one of their "authorized" repairmen to come to my house and fix it. True, I live in a rural area, but it isn't like I'm hundreds of miles from any of the three repair services they named. Apparently LG doesn't pay them well for warrantee repairs because they all wanted more money and refused the work!
I am going to turn all of the information and communications I have had with LG (by email thank goodness!) to my State's Attorney's Office.
Good luck in getting this repaired.
Sep 22, 2008 | Frigidaire Affinity ATF7000E Front Load...
LG TROM STEAM WASHER-WM2487 HRM
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap and softner.
Jul 31, 2008 | LG WD-14124RD Front Load Washer / Dryer
Front loading washing machines
not really front loaders have top loaders beat all the way but stay away from admiral and maytag .a front loader will wash your clothes using the soap that your top load failed to get out if i may suggest buy a frigidaire with a mechanical timer not electronic control more junk on them more to fail the best combo in my mind is a frigidaire front loader and whirlpool dryer front loaders use 2/3 less water 2/3 less soap and will get your clothes twice as clean they have no transmissions and are direct drive the most common promblems with them is having to clean out the pumps where people leave stuff in their pockets also you need to buy soap thats for front loaders its called high effincey or he soap and they will get your clothes make sure you read the installation guide and remove ALL the shipping braces
Mar 18, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
