Question about E-Machines M5310 PC Notebook
Can't dial up... no com ports listed in devise manager
The modem show working and com 3... but there are no com ports in device manager... setting up AOL the modem says ports are busy...
  • PwrHsePro Aug 18, 2008
    Thanks... tried this and the problem persist!
    Genius:
  • 2,028 Answers
This may be a simple driver glitch with the modem. Uninstall the modem drivers from the device manager and reboot. The machine will find the modem and reinstall the drivers. If this doesn't work, then check for driver updates or any utility drivers from the support site for E-machines.
Posted on Jul 25, 2008
Problem with not working right with dial up
Your dial-up relies on the internal modem to be working properly.
Check for your modem status using Device Manager.
If the listing for the modem has any yellow or red highlighting, then the modem software or hardware needs to be changed.
If you leave your PC plugged into a phone line, internal modems are easily destroyed by lightning storms or surges in the phone line.
If the Device Manager looks okay, then call your Internet Service Help Desk.
Feb 16, 2013 | Acer Aspire 5745P-373G32Mnks - Core i3...
My modem is not functioning
Uninstall and reinstall your modem driver.
• Click Start -> My Computer -> Properties -> Hardware Tab -> Device Manager
• All items in Device Manager are listed in alphabetical order.
• Select and click on Modems.
• Right mouse click on your Modem
• Left click on Uninstall
• Restart machine and test.
If you receive some errors like
633: The port is already in use or is not configured for Remote Access dial out.
678: There is no answer.
680: There is no dial tone.
777: The connection attempt failed because the modem on the remote computer is out of order.
Then you can use RegInout to fix such types of errors.
Hope it might help you.
Nov 13, 2011 | Dell Dimension 2400 PC Desktop
I am trying to set up a computer with dial-up internet. After working with my ISP we cannot determine if there is a fax modem in the computer. It there is, it appears to be disconnected and does not show...
If you are trying to determine if there is a modem in the computer, it will be easily seen on the back of the computer. (look for the phone connector with 2 or 4 wire pins) If there is one and it doesn't show up in device manager, open the case and find the make/model of the card that is installed. You can go to their website and download the software for it to install it.
Apr 19, 2011 | Computers & Internet
IC VERIFY CREDIR CARD SOFTWARE WONT DIAL OUT AFTER SWAPING HD TO A NE PC. EXTERNAL MODEM WORKS FINE, SETTINGS ON ICVERIFY POINTS TO MODEM COM PORT. SOFTWARE WILL NOT DIAL OUT. aNY HELP?
Ok,
There's really only a few reasons this would fail beyond the COM settings. First, if the computer you're using has actual serial ports on the board and you're using a USB modem or if there are more than one serial ports it's possible you have either got the wrong COM assigned or that you have more than one trying to use COM 1. This will not cause conflicts with newer USB based devices but can when using actual UART chips on the motherboard or a mix of USB and UARTs.
Go into device manager and check for additional ports. Disable all COM ports except the actual modem and try again. If it still fails, check for DMA and IRQ conflicts. Do this by going into Start>All Programs>Accessories>System Tools>System Information.
Once open navigate to System Summary>Hardware Resources>Conflicts and Sharing.
Check for any conflicts with COM 1 and it's related DMA settings or anything sharing an IRQ with the modem. If you find any devices conflicting or sharing IRQ or DMA with the modem either disable the device or go into device manager, double click the offending device, click onto the resources page and find an alternate configuration that uses different IRQ/DMA that won't conflict. This will require a reboot for most devices.
Sorry my answer would be faster but I'm shaking almost a decade worth of dust and cobwebs out of my brain that have built up since the last time I even used a modem for ICVerify.
Hope this helps, lemme know how you make out,
chris
Dec 23, 2010 | Computers & Internet
I am using zte usb modem FFF1 for internet access via reliance netconnect.whenever I connect the device to laptop it is shown as storage device but as soon as i install the driver software a driver not...
The ZTE modem when initially connected to any system loads as a storage device which contains the software necessary to install the modem. Connect the ZTE and open it in Explorer. Double click the setup file (.exe) to start installation. Follow instructions and allow installation to complete. The modem is automatically installed during this setup. Once completed restart and then your ZTE functions as a modem.
May 19, 2010 | Computers & Internet
When connect to internet says no modem
Hi.. Check your modem cables 1st of all for loose connection. And make sure that the OS your using is compatible with your modem, I know it might feel a bit strange..the link b/w modem and OS. But I had 1 personal experience when ma modem was not compatible with ma OS i was using (LINUX).
There are also possibilities tat your devise is not installed. So go to device manager. Check if any yellow exclamation marks there. Delete the device showing that, press refresh button, feed in your modem drivers when it asks.
Go to settings. Select control panel.In control panel, select system. In system
select devices(?) manager. Check there to
see if you have a COMM port enabled. The symptoms included that a commnication or dialing program can dial out.
Check your BIOS settings too..see if the port is dissabled..
N if nothing works use a diff modem..!!
Dec 02, 2009 | Systemax AOL Optimized PC (100607) PC...
Hardware conflict
You might have your internal modem set to the same com port as your com ports that are on your motherboard. You can try to go into BIOS and disable all com ports OR you can try to configure your internal modem in windows to use com 3 or com 4. Remember, that if your computer does have com ports in the back, then is is probably set to the same address as your internal modem so something needs to be moved.
Feb 11, 2009 | Hiro V.92 56K PCI DATA FAX VOICE MODEM...
Undetected com port 3
You may have to enable the other com ports. You go into the Control Panel and click on Add&Remove Hardware. When the first window shows up with everything that is already installed list, look at the top of the list. Highlite Add New Device. When ask, choose Select From A List. Then select COM Port and follow the wizard.
Nov 17, 2008 | Dell Dimension 8100 PC Desktop
Can't open Com 3 to connect to internet
hmmm..maybe you should go through this link, find toshiba icon, and get a new set of system drivers?
Mar 23, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Unable to detect modem for nokia 6070
download 6020 cable modem drivers from http://europe.nokia.com/A4144316 (yeah, no modem drivers for 6070). then go to device manager and update modem drivers to downloaded one.. that only will do.
Jan 25, 2008 | Nokia 6070 Cellular Phone
E-Machines M5310 PC Notebook Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
