Question about Sega Genesis Console
Fuzzy picture and no sound
I cant get my sega to work. I can see a picture but it is fuzzy with no color just black white and grey, thats with the rf connector. Its an older genesis, the one with the volume control on it. When i use the av cables that come with it i just get a black screen with an occasional white streak and the only sound i get are bleaps.
  • Anonymous Apr 14, 2009
    I have the same system, it's the real early one and it's not modified, it did have an AV output. I need some help as well because I get a fuzzy picture and only certain parts of the sound. I've got it cracked open right here but I can't see anything that's out of the ordinary.
  • 659 Answers
If it has av cable inputs on the console then its a modified system, and chances are something is either loose inside or fried.
Posted on Aug 11, 2008
Atari 2600, only get black and white, no color
Well i think that the rf switch might be causing the problem snowy tv scrren no colour or fuzzy tv screen then its the rf switch thats causing this type of a problem then. If using a digital tv you need to plug it into a VCR or a DVD player for it to work then.
Dec 14, 2011 | Atari 2600 Console
I need to know which wire on the 4 wire oxygen sensor (2 white, one grey one black) is the heat wire on a ford f-150 o2 sensor?
Hello! There are four O2's...Each O2 heater, left and right bank, front and rear, has it's own wire colors...These colors are "at the connector"...First series are the control ground sent by the PCM..
RR=White/Black...RF=Red/White...LR=Tan/Yellow...And LF=Yellow/Light Blue...........This series are the battery leads, hot when fuel pump relay pulls...RR=Violet/White...
RF=Red/Yellow...LR=Violet/White...LF=Red/Yellow...
If you have any questions feel free to ask...Guru...Saailer
Oct 20, 2010 | 2001 Ford F150 Styleside SuperCrew
Hi i have a sega megadrive 2 and have only just got it out, but now have a Bush digital TV and the Sega is on (power) but I can't either locate the channel or am confused on how it connects up to the Tv to...
I think those have the old style RF connectors.A coaxial cable with a grey or black box in the connection cable.Plug the coaxial cable from outside into the RF cable.Plug the RF cable into the TV coaxial input(regular cable input).On the back of the Sega,there should be a switch for CH3 or CH 4.Put the TV on the appropriate channel.If the signal looks bad,switch the selector on the Sega and change the TV channel.If you do not have the RF cable there is a place that still sells Sega accessories,but not Sega.They must have contracted with Sega.If you need the site let me know.
Aug 02, 2010 | Sega Megadrive Black Console
I recently found my old sega megadrive/mega-cd and I've dusted it off and tried to reconnect it but have found i'm missing the cable which links it to the tv. According to the instruction manual I'm...
I searched and Sega themselves do not deal with older systems,however here is a phone number to the place that can probably help.They are contracted for the older systems I guess.It is called an RF connector or RF cable too.(714)836-4981.I don't see your system on the list on the link but it wasn't on Sega.com either.
http://sega-parts.com/ is the older systems link.
Sega's main number is 1-800-USA-SEGA but good luck trying to actually talk to someone.No surprise there huh?
Good luck and game on!
Jul 26, 2010 | Sega Genesis 2 Console
Black and white Picture Sega Master System 2
Is this one of those much older Sega systems with the RF connector that plugs into the incoming cable from outside and the TV?If it is,there should be a channel selector switch on the back,CH3 or CH4.Try the other channel.If it doesn't go away,your RF connector is on it's last legs.
Jul 26, 2010 | Sega Master System Console
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Jun 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
Fuzzy picture on TV and NES when new RF adapter is cconnected
i had the same problem, and it was the rf unit itself. to resolve this problem i went to radio shack and purchased a special connecter. one side is an rca (male) to rf (female). when attached to a standard peice of cable wire, it acts as an rf unit. Also works with the sega genesis. hope that helped
Mar 30, 2009 | Nintendo NES Console
New vr-3 going into used 2004 Status. Current wiring has black connector and grey connector, also one blk/yellow stripe wire. Have wire colors written down, need to know what existing wires are -new radio...
According to www.the12volt.com The color codes for your vehicle are:
RADIO 12V CONSTANT |orange/black
RADIO SWITCH (ACC)|white/black
RADIO ILLUMINATE|green/white
LF SPEAKER|wht/blu - blk/blu
RF SPEAKER|wht/red - blk/red
LR SPEAKER|yel/blu - gry/blu
RR SPEAKER|yel/red - gry/red
Feb 24, 2009 | Clarion VRX935VD Car DVD Player
Bad signal on my sms 2
i had the same problem, don't use rf, use an ave cable you can find them on ebay
Apr 03, 2008 | Sega Master System Console
Cant get picture on tv from sega mega drive. concerned might be missing a part
Ok i have many sega systems and to connect a sega it sometimes depends on what version of the sega mega drive you have i will tell you how to connect your sega after you've already plugged in your power adapter. If there is a plug on the back of your sega that says RF out then you should have a TV out/ antenna in adapter. One end goes into your sega and the other TV out should go into your TV then if there is already an antenna in your TV unplug it and and plug it into your TV/ antenna adapter where it should say something like antenna in. Don't worry if you have cable or directv it will still work it just might be slightly fuzzy because of the old technology. If you dont have the RF out then you should have a plug in the back that says AV out and all you do is do the same thing only the TV/ antenna adapter you should have should be able to plug into the AV out plug. Any other concerns about your sega, like how to connect your sega CD to your sega console, or most of its other products just let me know and if this doesnt work let me know, thank you.
Mar 07, 2008 | Video Game Consoles & Games
Sega Genesis Console Logo
439 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Josh Whitehead
Josh Whitehead
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
