Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Hey man I got a problem with my Belkin (F5D8233-4) Wireless Router
My wireless won't work and I need your advice
  • Anonymous Apr 08, 2009
    I have Belkin Wireless Pre-N Router F5D8230-4 but i cannot customed any setting, it's require a password "Before you can change any settings, you need to log in with a password"
    Please some can resolved my problem..
    Thank you..
I recently bought a similar router, Belkin Wireless Router N, not Pre-N, but you can try going to and click on support center, networking support or there is a phone number and try to talk to a technician. 1-800-2BELKIN.
Posted on Oct 14, 2008
If the router does not give an automatic ip address via dhcp and you cannot connect to router menu, the router is dead buy a new one
Posted on Aug 31, 2008
My belkin f9k1002v1 router won't work.
A lot of things can keep it from working. Make sure there's lights and you have power, substitute ethernet cables, do a factory reset. Here's how I did the factory reset on my F9K1003V1.
Nov 02, 2012 | Computers & Internet
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
My Belkin F5D8236-4 v3 Router won't turn on. We had a storm last night and the power went out but the router won't turn on. I have tried to plug it into different outlets to see if that would work...
Try resetting the router. There should be a little hole somewhere on it with a button inside that you can press with a paperclip. Try holding that button down while you unplug then plug the router in while holding it (if possible). If that doesn't work, I'd suspect the storm might've damaged the router somehow. Was it plugged into a surge protector, and/or have you noticed any other issues with anything else that was turned on at the time?
Jun 16, 2011 | Belkin F5D8236-4 Router
Blinking orange light
if you got an orange light to the router, It means that there's no Internet connection or not working from the router. I might advice you to check the Internet connection from your ISP, then check the configuration of your router or you might needing to reconfigure the router.
Mar 10, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin wireless stopped working.
Well you can try to contact to belkin tech support and ask for online assitance hope they will fix your problem and you will be good to go.
Nov 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Reply to advice
wts the light status of the router and are able to open the router page and wts the Adsl connection status is it connected.
Nov 03, 2008 | Belkin 802.11g Wireless Desktop Network...
Belkin N Wireless Router doesn't connect to Modem
If router is brand new you should have a set up disk. the set up disk will walk you through it or you might log onto Belkin site to see a walk through set up. If you can access internet from modem to router to internet. That means router is functioning properly. To go completely wireless you will need to secure your network and setup your access codes. Definitely use the setup disk to do this. A unsecured wireless network is a nightmare waiting to happen. Good luck
Sep 01, 2008 | Belkin Modem connector (R6G064-R-50)
Yeah hey...belkin wireless router password reset
What is the brand of the router your using? This information will be from the router that you have. Use a wired connection from the router,check your default gateway (ipconfig) and type that numbers in your address bar. You will be able to access your set-up page, look for wireless tab and look for wireless security. You will see there your WEP key.
Jun 26, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
200 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
