Question about Video Game Consoles & Games
New 80gb PS3 will not display properly when connect to a SDTV using component cables. Standard AV cables work just fine.
  • 35 Answers
You have to change the display settings on your ps3 for it to adjust
Posted on Jul 27, 2008
My ps3 comes on alright, but it won't play games or movies
Hi
If it is a new connection you are setting up then check the Display settings for your PS3. You can check it by--
Go into setting, display setting and choose the cable type and then try to do the test. See this link for details--
Sony PS3 Display Settings
If the issue is not resolved then try using Component cables for the connection and check whether the PS3 works. If this works then connect the HDMI cable after the component cable is connected & then the PS3 will locate the cable. It'll then ask you whether you want to use the HDMI cable connection, select yes from there. And, if this doesn't resolve the issue then try connecting it with another TV or else this is a hardware issue with the PS3, not the TV. If it is less than 90 days old then you get it replaced and get a new one. Hope this helps...please post back for further assistance.
Daniel
Jan 06, 2011 | Sony PlayStation® 3 (80GB) Console
Ps3 tuning
Hello!!
Try connecting the PS3 with the different cable ... i mean the problem may lies with cable ... So give atry once ..
Jan 03, 2008 | Televison & Video
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    Sony trinitron kv-32fs10 component color problem
    check the av in puts of your tv, this sounds that your av jack has a loose joint on the connection under.
    May 24, 2010 | Sony KV-32FS10 32" TV
    Black and white display screen
    If you have an HDTV use HDMI or component to connect to get colour...if you have an SDTV and use the RGB cables unfortunately the PS3 will output NTSC signals for JApan/NA and your SDTV will accept PAL signals (EU). THere may be an adapter, but if you have an HDTV this problem should solve itself via HDMI/component cables.
    Aug 29, 2009 | Sony Playstation 3 (PS3) Console
    No picture or sound
    Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
    Aug 05, 2009 | Sony Playstation 3 (PS3) Console
    Playstation 3 not working with older model Pioneer AV receiver
    If you have set the component output on the ps3 for high def,ie 720p or 1080i and do not get a picture it sounds like the component input is not high def enabled on your amp,change the setting on ps3 to standard 576 output,or put picture into tv then sound into amp if you want to run 720p or 1080i.
    Hope this helps.
    CABLE GUY.
    Jan 01, 2009 | Audio Players & Recorders
    I have an sdtv and ps3 dosen't show picture or sound
    I had the same problem and was told to turn off the console and hold the start button down for 5 seconds. Have not tried it yet since I am at work.
    Dec 15, 2008 | Sony Playstation 3 (PS3) Console
    PS3 streches off the TV Screen
    Try holding the power button on the ps3 for about 10seconds. It should beep as it normally would turning on, carry on holding the button until it restarts. This should restart the ps3 in standard mode so that it can be viewed via rca/scart connection.
    Aug 17, 2008 | Sony Playstation 3 (PS3) Console
    Video Game Consoles & Games Logo
    41 people viewed this question
    Top Video Game Consoles & Games Experts
    James Wishart
    Josh Whitehead
    Josh Whitehead
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
