SOURCE: epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
SOURCE: Black ink not printing and colour ink very faded
Check the ink status of the printer's cartridge.
SOURCE: HP Deskjet 54280 won't print
Try cleaning the print heads. You can find more troubleshooting info in the manual:
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
SOURCE: My printer will not print in black and white, as
Believe or not, a bit of color ink is require to make true black. However, from most application you can go in to the printer preferences and click the Color tab. Check the print in Grayscale and click the Black print only option. My instructs are based on an HP model printer. The preferences can be a little different between brands. But, you should have similar options. Check your printer's manual for more specifics.
