Question about Samsung Dryers
Do I need a water line hookup for the steam dryer?
    Genius:
  • 1,028 Answers
Only if you intend to use steam option .l
Posted on Jul 26, 2008
Can I use my whirlpool DRYER without hooking up water ,I am unable to hook up water to the dryer
Your dryer does not have a water hookup therefore the dryer does not need to have water connected to it
Nov 27, 2017 | Whirlpool Dryers
Does my Samsung dryer have to be connected to water to function
If it is a washer / dryer combination, yes, you will need water. If its a dryer only, then no, unless it is a steam or condenser model. If it has a hose with a tap fitting out the back, you will need to connect it to water. Condenser dryers often have a drain hose coming out the back. This goes into the sink to get rid of the water. Have a look at the instruction book or look on line for your Samsung model for information.
Sep 17, 2017 | Samsung Dryers
My dryer is leaking water at the inlet , i disconnected the water supply going to it, the dryer functions, but no steam option, and what is broken to cause it to leak?
I would start by redoing the connection at the dryer. Should be a hard plastic line with a nut and a ring (ferrel). You will need a new ferrel. Slide the nut up the plastic line and cut the line on the nut side of the line. Slide the new ferrel on the line and reassemble.
Feb 27, 2015 | Dryers
Water coming out of the back of the dryer
When a dryer usually produces visable water from any part of it's self, the suggestion would be a completely restricted vent line. Such restrictions could be from nests from animals, excess lint, a dip in the vent hose causing lint and water to collect. Since the dryer is leaking water, it is heating and therefore creting steam in an effort to dry the cloths, with a clogged vent the steam has no where to escape to and thus condenses within the dryer and leaks out. The vent needs to be checked by a wualified vent servicing company from the back of the dryer to the point of exit of the home. Pleazer Appliance...
Jan 13, 2015 | Maytag Neptune MAH5500B Front Load Washer
Why does my wrinkle release not work?
Poor water pressure? Corroded water line plugged with calcium from hard water? Water inlet valves not open? Bad steaming printed circuit board?
Jun 22, 2014 | Samsung 7.4 Cu. Ft. 13-cycle Steam Gas...
The water spray for steam cycle in Samsung front load dryer smells musty. The clothes smell bad from steam cycle only.
water build up in the steam water resevore sitting to long and getting that mildew smell check the hose lines going into it and from it. for blockage
May 27, 2014 | Samsung Dryers
How hot does a whirlpool cabrio dryer get
It can because it has a water line coming from washer line it causes steam for you dryer.
Dec 15, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Bravo steam dryer getting hot but clothes are still damp
Hello Shawn.
Glad to see you got it sorted out.
Maybe you place a "how to.." tip for a wider audience.
PS- while reading your added comment / update re the fix, the 'comment' block suddenly vanished as I exited from it!
Not sure what happened there.. ;[
Maybe try retyping it?
Regards,
Clive.
Dec 04, 2017 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Water pouring out of cold water connection the hookup is only connected to the hot water because the steam hookup is suppose work for hot water.... So they say??????!!! Is there suppose to be another hose...
YES YOU NEED TO EITHER PURCHASE A SCREW ON PLUG FOR THE COLD SIDE OR HOOK UP A HOSE FROM A COLD WATER VALVE TO THE COLD SIDE OF YOUR INLET WATER VALVE ON THE WASHER (YOU SHOULD HAVE GOTTEN A HOSE WHEN YOU BOUGHT IT, IF NOT YOU CAN PURCHASE ONE AT YOUR LOCAL HARDWARE STORE OR APPLIANCE PARTS STORE , OR SEARS PARTS DIRECT. LET ME KNOW IF THIS WAS HELPFUL!
Mar 10, 2011 | Frigidaire Washing Machines
Dryers Logo
364 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
