Question about LG Dishwashers
LG dishwasher model lds5811st error LE - LG Dishwashers
Per instructions in other's posts, I removed door panel, but no wires broken, so called LG and local authorized LG repair and they tell me motor sub-assembly needs replacement, cost $160 for parts, $200 for labor, which is making a new dishwasher look attractive.
Posted on Jul 26, 2008
MNTECH
  • 1543 Answers
SOURCE: ERROR CODE "LE " ON LG DISWASHER
You should check for that the pump motor turn freely. You will have to remove the sump cover in the bottom of the dishwasher and manually turn the pump impeller. (note: screw holding the impeller on the motor shaft is a left hand thread) There may be an object there or at the cutting blade a bit lower down that is preventing the motor from turning. Motor should turn easily, smoothly, and quietly. There have been issues with magnets in the motor windings cracking, resulting in hard to turn or noisy motors. Also, models produced with serial numbers 501KW_____ to 702KW_____ may have wiring which has become embedded in the door insulation material, softening the wiring insulation, and causing a short to the motor. The fix for that is to replace the wiring harness and outer door liner with one with a different type of insulation. (not much fun to do)
Posted on Aug 27, 2008
  • 37 Answers
SOURCE: What does the error code LE mean on my LG Dishwasher
MAin wash motor needs replacing
Affordable Appliance Repair
Lake Forest, CA 92630
Posted on Aug 22, 2009
rickzilla
  • 706 Answers
SOURCE: Error code LE shown on
Hello JA12345,
Here is a link to the service manual for your dishwasher. Page 25 discusses the error code...
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Hope that helps you resolve your problem..
Regards,
Rick
Posted on Dec 13, 2008
blueextc3221
  • 15935 Answers
SOURCE: I have a LG diawsher, model # LDS5811ST that is
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
LE means locked motor disassemble the filter and work your way down to the macerator(steel chopper blade) remove it and see if the side labeled "this side up" is really up, its in english... dont think the chinese labourers paid attention to the warning cause i have seen alot that were wrong way
You also should remove the door panel and check for a broken wire (usually the blue one)
If all the wiring checks out - it is most likely a broken or locked up impeller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 31, 2009
SOURCE: I have a LG Dishwasher Model LDS5811ST. The code
Did you find anything out? Mine won't drain either.
Posted on Sep 14, 2010
How do I replace dishwasher door hinge spring?
http://www.repairclinic.com/PartDetail/b200p9/LG-Dishwasher-Hinge-Spring/4970ED4004D/1337779?modelNumber=LDS5811ST#repairHelpVideoTabs
Oct 07, 2014 | LG Dishwashers
Lds5811st won't drain error le
have to change control board on lds5811st water not draining on last cycle already changed pump
Nov 17, 2012 | LG Dishwashers
May 14, 2010 | Dishwashers
I have a LG Dishwasher Model LDS5811ST. The code LE is showing and my water will not drain. The motor seems to be straining? What can I do?
( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked. Correct wiring connections. Replace the cause of resrtiction. Replace the washing motor. Replace the PCB.
Mar 24, 2010 | LG Dishwashers
I have and LG nodel #LDS5811ST and after ad couple of minutes it stops with the code LE showing in the time window, what does this mean!
The wire harness has probably degraded and broken inside the door panel of the unit.
This unit may need a new wire harness, Main PCB, Sump and inner door liner.
Depending on serial#
Contact LG @ 1 800 243-0000 they may help you out.
This is a known issue on older dishwashers.
Jan 14, 2010 | LG Dishwashers
locked.
locked.
Remedy:
Replace the PCB.
Aug 31, 2009 | LG Dishwashers
My LG LDS5811ST has error code of IE Where do I
1-Check if the water Inlet Hose is kinked.
2-The Water Pressure is very low.
(below 10 psi)?
3-Inlet Valve is OK?
The filter of Inlet Valve is clogged
by water filter?.
The Impeller of Air Guide is bound
Jul 03, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Error code LE shown on a LG dishwasher model LDS5811ST and this code is not given on the standard error code list.
Hello JA12345,
Regards,
Rick
Dec 13, 2008 | LG Dishwashers
LG Model LDS5811ST error code LE
LE is a motor problem.. You can find details in the service manual at this website link... http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Page 25 discusses that error code and possible solutions
Hope this helps...
Sep 06, 2008 | Dishwashers
Dishwashers Logo
544 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
