Question about Frigidaire FEQ1442ES Electric Dryer
Turning no Heat, clean filter lights on while turning
My dryer keeps turning and does not produce heat.
  • If started, the clean lint filter light comes on while the drying light is on as well (with no heat). The filter is always cleaned after every load. lately.
  • I let it rest, selected another cycle and started it and this time it stayed on the cool down cycle with the clean filter lights on. (still no heat).
  • When it is working (that is turning with no heat) all the lights on the cycle panel continue to blink at the same time at certain intervals.
  • I have checked the duct and it is not clogged. I need help and need it soon please.
  • AbbeyG Jul 27, 2008
    I verified the proposed solution it turned out that none of it was any of the above
    However, I ran the function test sequence. everything worked except whenever I turned the rotary knob for the temp setting., there was no key beep with any of the settings (HIGH, MEDIUM,LOW) except whenever I turned it to NO HEAT.
    I am thinking is it something with the knob circuit or ..... Please help...
I had a no heat problem although I di not have the blicking lights you had. After I changed the control panel (a very expensive item) because the maintenance manual says so, I had no success, same problem. After reviewing the print I noticed the control thermistor. I checked the manaul again and it says if open or shorted check wiring and check thermistor for a 50 Kohm value. It does not say it has anything to do with the heating circuit. But, I pull the thermistor out and it reads 2.79 Kohm. So I set up a variable resistor to 50 Kohm and connected to the 2 leads, turned on the dryer and bingo it worked again. I have the part on order which is only a $10 item. So I lost $200 on this learning experience because they won't take back special order items. So my word of advice is that the manual does not tell you everything to check but they do tell you how to check most sensors so please do this before you change the control panel.
MK
Posted on Sep 15, 2008
Usually heat element or high and low limit sensors need changing, check vent lines are not plugged or 220 breaker if split breaker is only tripped on one side?
Posted on Jul 25, 2008
Problems with frigidaire affinity dryer model gle02152es1.
Hello ljdixon226 - From what you have described the unit could possibly have a communication problem with the control panel. However, if the unit is not producing any heat please have a professional diagnose the heating element and the blower assembly as well. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Oct 08, 2012 | Frigidaire GLEQ2152ES Electric Dryer
White Knight gas tumble dryer BG 457 starts and ignites with the orange light coming on, works for about a minute producing heat then the orange light goes off. The dryer continue to turn but the orange...
I feel you need a new igniter or thermocoupler. Just remember those igniters are activated many times to keep constant right heat for the machine to do its job.
Jan 25, 2018 | Dryers
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Dryer produces heat, but clothes don't dry
Sounds like the vent has a lint build up inside of it. A moister sensor detects any lint build up and keeps the heat in check. The dryer will produce very little heat this was. Clean the entire venting tubing and it shall run better for you
Jul 08, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
The dryer will not produce heat and blowing lint
check where your dryer vent goes through your outside wall they sometimes clog up with lint and cause the escaping heat to recirculate back to your dryer causing the sensor to read the dryer as too hot clear all lint from the outside vent so you can feel the air coming out very steadily and quickly If this works you are all set otherwise check your heating element
Jan 04, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Kenmore 70 series that wont heat up can i just
well did check if burner is coming on is filiter clean is duck clogged. there should be sensor near the pilot light it should be close or even within the pilot light.
Jun 24, 2009 | Dryers
Bosch Axxis Starts and stops
The lint light keeps coming on and shuts the dryer off so clothes are not dry. I checked the filter and it is clear. Now the bottom of filter is cracked (plastic part) so I need to replace. But why does the lint light come on now after 5 years of use? It never came on before even when the lint filter was full?
Apr 20, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Hi the my filter light keeps flashing and iv got no heat!
My guess is that the heater element has gone out. There could also be a lint clog in the exhaust vent...it takes air out through the filter...across the heater element....and back through the tumbler to heat the clothes. This is usually what causes heat elements to go out is the excess lint that gets on them and causes them to overheat and burn out!
Dec 14, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Clothes not getting dry
sounds like perhaps you are losing your heating element...could be electronic, but it's most likely the actual element needs to be replaced...
Apr 25, 2008 | Whirlpool GGQ8831L Gas Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
324 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
