Question about Uniden Radio Communications
Programing How do I program this scanner? I have a list of frequincies I want.
Stumbled upon a blog where someone else was looking for the same info. Somebody posted an answer and it worked!
Posted on Jul 26, 2008
Unable to copy because "The functions listed cannot be used because the scanner is not available?"
First of all make sure that you've correctly connected the scanner to your computer, and that the device is powered on. Then check if the scanner software and drivers are installed, to check these please follow the steps given below:
-Press 'Windows logo key' + 'R' key on the keyboard.
-'Run box' window will open up and type in 'Control Panel' then hit 'Enter'.
-Look for 'Programs and Features' and select it.
-Now check if 'Scanner' is listed in the installed programs list.
If the scanner is not listed there, then you have to install the software and drivers from the scanners manufactures website.
In case if scanner is listed in the programs and connected to the computer, try updating scanner drivers from device manger. To do these please follow the steps given below:
-'Run box' window will open up and type in 'devmgmt.msc' then hit 'Enter'.
-Look for the 'Scanner' and click on it.
-Select 'Driver Tab' and then click on 'Update Driver'.
GuruAid.Com
Mar 10, 2016 | Office Equipment & Supplies
HOW TO PROGRAM LOCAL EMERGENCY FREQUINCIES?
To check your area for what frequencies you need please go to www.radioreference.com. Click on Database, choose frequency database. Then click on your state, and then your county. When you scroll down the page it will show your frequencies and systems.
May 25, 2015 | Uniden Bearcat Nascar - Hand Held Scanner...
I HAVE A UNIDEN BC80XL HAED HELD SCANER RADIO. MAYBE IM STIPID BUT I CANT GET IT PROGRAMED FOR ANY FREQ. i NEED SOME REALL HELP THANKS
Your first step is to compile a list of active frequencies in your area. You can find a very good database at:
www.RadioReference.com
Next, mark or highlight the frequencies that you want to program, making sure that they will work with your scanner. See your scanner manual for a list of covered frequency ranges. The BC80XLT will hold 50 frequencies.
Once you have the desired frequencies, you're ready to begin:
- Power the scanner ON.
- Press the MANUAL key.
- Enter the channel number that you want to program (01 - 50). If you're going to program the entire scanner for the first time, start with channel 01.
- Use the keypad to enter the desired frequency, including the decimal point (e.g., 146.075). Zeros at the end of the listed frequency need not be entered (e.g., 805.25000 should be entered as 805.25).
- Press the E key to save your program information.
- Press MANUAL to advance to the next channel, then start by entering the frequency.
More detailed instructions are in the factory manual. If you don't have a copy you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC80XLTom.pdf
Bill B.
Listening in since the 60's
Feb 08, 2011 | Uniden BC60XLT-1 Handheld Scanner
How do you find someone to program a Bearcat scanner?
The 370 is a straightforward scanner and fairly simple to set up, and you should be able to program it yourself with no problems.
Your first step is to make a list of the frequencies that you want to program. Your scanner has the capacity to hold up to 300 frequencies, so you should probably write out a list or type it up in your computer. There's an area in the scanner operating manual for listing your frequencies, but it doesn't have space for you to list the users. You can find a comprehensive database of active frequencies in your area by visiting:
Once you have your list,
1. Power the scanner ON.
2. Press the E/PGM key to enter the programming mode.
3. If the displayed channel is not the one you want to program, enter the desired channel number and then press HOLD.
4. Enter the desired frequency - including the decimal point.
5. Press E/PGM to enter your data into the scanner's memory.
6. To program the next channel, press the UP or DOWN arrow key, and then start again with step 4 above.
7. To exit the programming mode, press the HOLD and SCAN keys.
The scanner operating manual contains more detailed programming instructions, along with information on how to use features like SEARCH, Weather Alerts, and Band Search. If you don't already have a copy of the manual, you can download and print it here:
http://www.uniden.com/pdf/BC370CRSom.pdf
If you run into any problems while programming, just let us know.
Bill B
Jul 01, 2010 | Uniden BC370CRS Base Scanner
Uniden 30 ch scanner i have locked out all channels.
Each channel with the zeroes means that it is a blank - with nothing programmed into it. Going to any one of them and programming a frequency will get rid of the zeroes and switch off the lockout. It's picking up weather, so it's working. Sounds like you just need to find and program active frequencies for your area, and the place to find them is:
If you need it, you can download and print the manual for the BC60XLT-1 here:
http://www.uniden.com/pdf/BC60XLT-1om.pdf
Bill B
Apr 08, 2010 | Uniden BC60XLT-1 Handheld Scanner
How to program my model 8065MO scanner
There should be a switch in the back,move it.Go to RadioFreq.com. for listing in your area,try channel up to get channels you want to program,push program..hope this helps you some..........
Mar 01, 2010 | Uniden BC340CRS Base Scanner
Delete from add delete at control panel
The only way to modify the add/remove programs list is to edit the registry. If you are uncomfortable doing this, get someone to help who is, or just leave the registry alone.
It's best to back up the registry in case you make a mistake.
To back up your registry, see this article.
On to the fun part. Follow these instructions exactly. Note: this applies to Windows XP only. If you have Windows Vista, please modify the question.
  1. Click Start, and then click Run.
  2. In the Open box, type regedt32, and then click OK.
  3. In Registry Editor, locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
  4. In the left pane, click the Uninstall registry key, and then click Export on the File menu.
  5. In the Export Registry File dialog box that appears, click Desktop in the Save in list, type uninstall in the File name box, and then click Save.
  6. Each key listed under Uninstall in the left pane of Registry Editor represents a program that is displayed in the Currently installed programs list of the Add or Remove Programs tool. To determine which program that each key represents, click the key, and then view the following values in the details pane on the right: DisplayName: The value data for the DisplayName key is the name that is listed in Add or Remove Programs.
    -and-
    UninstallString: The value data for the UninstallString key is the program that is used to uninstall the program.
  7. After you identify the registry key that represents the program that you removed but which is still displayed in the Currently installed programs list of Add or Remove Programs, right-click the key in the left pane of the Registry Editor window, and then click Delete.
    Click Yes in response to the "Are you sure you want to delete this key and all of its subkeys?" message.
  8. On the File menu, click Exit to quit Registry Editor.
  9. Click Start, click Control Panel, and then click Add or Remove Programs.
    In the Currently installed programs list, verify that the program whose registry key you deleted is no longer listed.
  10. Do one of the following:
    • If the program list is not correct in Add or Remove Programs, double-click the Uninstall.reg file that you saved to your desktop in step 5 to restore the original list of programs in the registry.
      -or-
    • If the program list is correct in Add or Remove Programs, right-click the Uninstall.reg file on your desktop, and then click Delete.
Mar 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Not hearing certain frequincies
not all scanners will pick up the same, the hand held can't pick up frequency as far as the other one.
Mar 11, 2009 | Radio Shack Pro-97 Handheld Scanner
Radio Communications Logo
63 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
