Question about RCA RS2620 Single Cassette Deck
Our sanyo RD 5340 Cassette tape deck has 3 drive belts inside. They have come off. I believe I can fix it, but don't know which belts fo wherd. Do you have a picture of how it should look?
    Welcome Back:
    Visited the website for 2 consecutive days.
I also have a Sanyo RD5340 with broken (worn out) belts which partially "fell" off.
It is obvious Van Lake doesn't know what he is talking about. You can get a
complete set of replacement belts at this link for $17
As to a photo of how they are supposed to look, hopefull another owner will
post one because I would like to see it also. Good Luck.
Ken H
Posted on Oct 16, 2011
  • 319 Answers
Belts just don't fall off, unless someone removed them. Please take unit to have them replaced
Posted on Aug 03, 2008
Need to know how to replace belts on a Sanyo RD R60 Stereo Cassette deck circa 1987
Well these machines are not always easy to put parts into and there are some things to do that are not written in the manuals even if you get them. Often times the transport has to come out of the unit and then brackets and motor plates have to be removed to access the belts. This is just the reality of the job and why it can take so much time to do it. Just replacing belts in a machine does not guarantee that the unit will work well just from those belts. New belt will allow the torque to be transferred but the speed of the motor still needs to be set and wow and flutter measurements to determine if the deck is usable. Some belts of the wrong type will result in high wow and flutter. It depends on oiling and belt tension and if the reel torques are correct.
The real answer to your question is not how you put the belts in but that you need to have it worked on my a Technician who knows what they are doing. Most deck owners are not set up with experience or equipment to get the correct job done.
Jul 29, 2012 | Audio Players & Recorders
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
Drive belts on tape decks are mostly universal. You only need to measure the diameter of each belt in mm and then enter the result in Google as "Cassette drive belt ??mm".
Mar 13, 2011 | Teac W-865R Single Cassette Deck
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
Fisher cassette player and Fisher cd player need belts
I believe that FISHER was trade brand of Sanyo if that helps?
Mar 07, 2009 | Audio Players & Recorders
Unit may have defective idler or gear. Have serviced
Aug 05, 2008 | Sony CASSETTE DECK Single Dual Cassette...
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Cassette player on mx-d302t
Hi As you know cassette decks have been around along time, and as such they are fairly robust. The vast majority of the time, problems like you are describing are the result of a broken drive belt, or bad capstan motor. This is not true for all, but if you have favorite tapes you wish to play, you need the deck fixed, and if the problem is drive belt or motor, the repair normally should not be hugely expensive. Hope this helps, good luck!
Feb 23, 2007 | JVC TD-W118 Single Cassette Deck
RCA RS2620 Single Cassette Deck Logo
477 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
