Question about Lexmark X73 All-In-One InkJet Printer
Will not stop making this banging noise
I STOPPED MY PRINTER AND REFILLED MY CARTRIDGE, WHEN I CLOSED THE PRINTER DOOR, IT NOW SLAM AGINST THE SIDE OF THE PRINTER WALL. NOW IT WANT TURN OFF OR STOP BLINKING, NOW I CAN'T GET IT TO DO ANYTHING, NOT EVEN LINE UP THE INK CARTRIDGE. CAN YOU TELL ME WHAT I DO TO FIX THE PROBLEM...
  • 1 more comment
  • CUMMINGSCARL Jul 30, 2008
    I'VE TRIED TO RESET THE ENCODER STRIP ON MY X73 PRINTER, BUT THE PROBLEM IS STILL NOT FIXED. WHENEVER I OPEN THE PRINTER DOOR OR CLOSE IT, THE CARDRIDGE STILL DOESN'T CAUSE THE CARRIER TO MOVE OR STARTS TO BEGINS TO PRINT. IT STILL SLAMS AGAINST THE SIDE OF THE PRINTER WALLS. IS THERE SOME OTHER SOLUTION THAT I CAN TRY....
  • tommyhuffman Nov 09, 2008
    I changed the ink cartriges and now when I turn on the printer, it slams to the end. The endcoder strip is in place, any suggestions.
  • Anonymous Nov 23, 2008
    I am getting the same reaction with the banging against the side of the printer what is the solution
    Genius:
  • 2,035 Answers
This is problem when the encoder strip is out of place you need to follow these steps carefully :
To resolve this issue:
  1. Open the front cover of the printer and locate the encoder strip. This is the thin silver/clear strip that runs across the printer behind the cartridge carrier. If the encoder strip has come out, it will cause the printer to go into a carrier stall.
  2. Remove the power from the printer and slide the cartridge carrier to the middle of the printer.
  3. Place your index finger on each side of the carriage onto the encoder strip.
  4. Slightly push it down and back up to get the strip back into the slot. (On the back of the cartridge carrier, there is a small slot that the encoder strip fits into.)
NOTE ::: Please do it gently do not break the strip or it cannot be used again...
Posted on Jul 26, 2008
Lemark Z52 Inkjet
Hello, First of all, let's start with some simple questions. 1 Was the cartridge ever refilled or is it in the original state? 2 How exactly did this occured? I'm asking this because most printers have a limited space inside them for the cartridge to move around when printing. If they don't fit exactly as they should, they will most likely hit something in their movement when printing. If your cartridge was refilled maybe the person who did that didn't attached the cartridge top part properly and now it moved out of position and hits the inner top of the cartridge housing. Please provide me first with these informations so I can better assist you.
Sep 09, 2007 | Lexmark Color JetPrinter Z52 InkJet
I have a canon pixma mp250 and error P07 flashing.Now,I refill blac and colour cartridges,and clean ink absorber,but still flashing P07.How to reset printer? Best regards, Misko
its mean absorber full..(i think)
Check this steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
1 Press the power button to turn off the printer.
  • 2 Hold the "Stop/Reset" button while pushing the power button. While still holding down the power button, release the "Stop/Reset" button and then push it twice in a row.
  • 3 Wait approximately 20 to 30 seconds until the LED shows 0.
  • 4 Push the "Stop/Reset" button four times in a row.
  • 5 Push the power button twice.
  • 6 Turn off the printer by pushing the power button one more time. The printer is now reset. Next comes resetting the counter on the cartridge.
  • 7 Unplug the power and the USB cables from the printer.
  • 8 Open the cartridge door and hold down the power button.
  • 9 Reconnect the power cables while still holding down the power button.
  • 10 Close the cartridge door and release the power button. The ink cartridge is now reset.
  • Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    When the button is pressed to copy, the copier makes a noise,which is not normal, then puts the copies through, but they are blank. no indicators are showing.
    There is one simple thing you can try. Open the right side door, then the front door. Slide the toner cartridge out. Then slide the drum cartridge partially out then lightly "slam" it back in to reseat the drum cartridge. Re-install the toner then close the front and right side doors. Try a copy and see if this has repaired the problem. If not then try opening and closing the right side door another time or two. If this works then great. If not then you will need to call your local service company to have the machine looked at. Most of my customers have had either the right side door open/close or the removal/re-installation of the cartridges resolve their problem.
    Good Luck and Thank You for using Fixya.
    Sep 20, 2010 | Sharp AL 1631 Copier
    Lexmark z617 printer not working, printer cartridges shooting from side to side when poweed on or lid opened & closed
    When you say "printer cartridges shooting from side to side when poweed on or lid opened & closed", do you mean that it's banging from side to side? Turn off the printer. Remove the cartridges from the printer. While the cover of the printer is open, check inside for anything out of the ordinary like any tapes or strips that are loose. If none, turn off/on printer and reload the cartridges. If the banging noise is still present, I suggest you contact Lexmark Technical Support to further investigate the problem. It might be a mechanical problem in the printer.
    Jul 15, 2010 | Lexmark Z617 InkJet Photo Printer
    Lexmark 5400 cartridge carrier slams up against back???? Won't stop!! It's a new printer, put in a high cap black and low cap color cartridge. Any ideas how to fix this?
    Cartridges may not be seated properly. Remove all the cartridges from the printer. Close the cover. Unplug the printer from the power source. Wait for about 10-15 seconds. Plug printer back to power source. If printer ink cartridge carrier still slams on the sides, encoder strip of the printer might be damaged. If it's still within warranty from where you bought it, have it replaced at that store. If ink cartridge carrier is not slamming to the sides, re-insert the cartridges. Make sure there are no obstructions along the carrier's path. Close the cover. Let the printer print the alignment page. If it's still going to slam the carrier, have it replaced.
    Apr 07, 2010 | Lexmark 83 Color Ink Cartridge (Twin Pack)...
    Lexmark x2500 the printer carriage wont stop it knocks on both
    Hello. It seems that you have a mechanical/hardware problem in the printer itself. Remove the cartridges from the printer. Unplug the printer from the power source. Plug it back to the power source after 10-15 seconds. When the printer's ready, insert the cartridges and make sure the cartridges are properly seated and locked in the carrier. Make sure there's no foreign objects blocking the carrier. Close the cover. Let it print the alignment page all the way through without cancelling it. If it still makes the banging/knocking sound, I would advise you to call Lexmark. That is a sound of a defective printer already. Good luck!
    Mar 27, 2010 | Lexmark X2500 All-In-One Printer
    Canon Pixma iP 6210D: cannot replace cartridges
    the drive control is malfunctioning and costs more to repair than replace
    Jul 07, 2009 | Canon Pixma iP6210D InkJet Photo Printer
    Tries to print, but then ink cartridge moves to left and it all stops
    the printer gears assembly is brokem or gor cracked so it is giving this message that ---cannot complrte print task--- just get that assembly replaced to make it proper. it will cost u near $20 for the assembly.
    Mar 18, 2008 | Lexmark Color JetPrinter Z23 InkJet
    Lexmark X73 All-In-One InkJet Printer Logo
    212 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Roopesh S
    Roopesh S
    Sanath Kumar V
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
