Question about Dell OptiPlex SX270 PC Desktop
No beeep, no start up power not image - Dell OptiPlex SX270 PC Desktop
  • 1 more comment
  • basgitaar666 Sep 30, 2008
    My optiplex sx270 won't startup anymore. The amber light on the motherboard is burning but there's nothing happening. I even won't get any signals on the little lights on the back of the pc.
    The pc worked very well until now. No blown caps on the MB.
  • biscuitron Oct 14, 2008
    same problem exactly
  • skankyvoodoo Nov 10, 2008
    I have EXACTLY the same problem. I tried heating the computer with and without the top casing on, with a blowdryer ... but still nothing. The fans are getting power because they don't spin freely when I spin them by hand, and the computer is giving off heat. I'm beginning to wonder if this chicken **** power button, or the chicken **** case contact switch is faulty. I have two of these machines with the exact same problems btw.
I have the same issue - identical.
My sx270 gets relatively little use and spends a lot of time powered off. The location is also an indoor, but unheated room. Temperatures are therefore low (but not freezing) in winter. Being by the coast there is also a certain level dampness in the air.
This fix is clearly lo-tech and short-term. But it has worked for me more than once and may be enough to help some of you out in an emergency.
I have found that by gently warming the PC first (no kidding!) with a hairdryer set to low seems to do the trick.
  • Switch the power supply off at the wall outlet.
  • With a hairdryer set to low, gently blow warm air all around the casing and down through the top vent for two minutes or so.
  • Reconnect the power supply (you should hear the PC fan kick in briefly) and switch on.
Once started and "warmed-up" the PC is fine to shutdown & reboot etc and seems to behave normally. Only if left off for a few days does the problem return. I suspect dry joints on the motherboard or an issue with the capacitors as reported elsewhere but have not yet taken a closer look at the motherboard.
Hope this helps.
Posted on Nov 09, 2008
Why do I hear strange sounds when turning off the engine and getting the key out?
Best Manuals I think some wiring problem for the easy and the best solution download the repair manual of your car :)
Jan 16, 2016 | Dodge Cars & Trucks
My lg fridge keeps beeeping model number gr642apa 8 years ago the beeping is driving me insane but everything else is workin only beeping all the time
http://www.manualslib.com/manual/692499/Lg-Gr-642apa.html
This is the link to the manual for your model. The beeping fault codes are covered starting on page 19 and get into detail by page 22. There are a number of triggering events or causes so you should read about them and try what the manual describes to try and turn the beep off.
Nov 25, 2014 | LG Refrigerators
Tried to upgrade my ram modules from 512 to 2gb. also installed a new video card (for a moment... but then removed it when the problem occured). now when i power up, i get a steady...
what type of ram did you upgrade with it should have been DDR and keep the same brand/type of ram modules the same check the ram sockets make sure they are clean and the ram is securely seated The ram modules should have either of these 2 the same 1 GB 184-pin DIMM DDR PC 2700 memory module 1 GB 184-pin DIMM DDR PC 3200 memory module
Jul 01, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
When i put the power into the computer, the computer gives sound
its a bad or not seated correctly ship on the motherboard...could be RAM chip-check that all is seated securely
May 08, 2010 | AcerPower 1000 (AP1000EA380M) PC Desktop
FE-330 THE SHUTTERS KEEPS JAMMING STRANGE NOISE
i am having the same problem with mine , its been like it for the past year now. i am only 14 so my parents think i have dropped it bu i havn't i need a soloution quick because i love taking photos of me and my friends. the olympus f3-330 it a really good cam' but now it doesnt even switch on or turn off . ! you cannot take pictures and the screen comes up in lines and make a beeep beeep noise then the lense goes in and out : / .
Oct 15, 2009 | Olympus FE-330 Digital Camera
The computer makes a loud beeping sound 5 times
Mass storage device is a usb drive, flash memory etc.
If you disabled the usb device, it will no longer work, that is why you do not hear the beeping any more.
You need to get the correct device driver for your usb so it works correctly.
I hope this helps.
Good Luck.
Mar 13, 2009 | Computers & Internet
Help with server boot problems flashing orange lights etc
Seems the RAID is broken. You may see which drive (hot swappable?) it showing an error code with its lights in front. If not, I would suggest re-seated all drives.
If you see one that is not right, remove it all the way, while it is on, then push it back in, it should try to rebuild the raid on the drive, if it still fails, you will need to replace the drive.
Not sure what RAID you are using or how many drives, so feel free to explain more.
G'luck
Oct 24, 2008 | Dell PowerEdge 4600 Server
Toshiba S200 not starting.power LED blinking with beep sound
Please try to take out the battery and power on using the ac adapter alone. If it works, it is okay to put the battery back in. Leave battery in for a few minutes then try to restart using the battery alone. Hope this helps. Thank you.
Oct 02, 2008 | Toshiba Satellite A105-S2001 Notebook
Constant beeping when booting up
It is just keypad problem.needs servicing the keys.
Jul 07, 2008 | Acer TravelMate 2300 Notebook
Memory slots DiMM A1&A2 does not work
Fixed the memory well and and insert the memory one by one.
first insert 1 memory and test, and then so on.
If not work work clean the slot and also the memory.
Jan 08, 2008 | ASUS A8N-E Motherboard
Dell OptiPlex SX270 PC Desktop Logo
117 people viewed this question
Alun Cox
