Back to:
Tags:
Washing Machines
Generic problem for all Washing Machines
Hi yesterday i changed th brushes
posted by shadowman42 on Jul 25, 2008
Hi
yesterday i changed th brushes on a friends washing machine-- tested without a load in and all was fine-
today he says it is trippint the trip switch and now it is not moving ata all- the machine is 10 years old but in good condition- i have in the last 2 yeqars changed the spider assembly- water pump heater belt and all was ok i am thinking it is the armature on its way out- should i put the old brushes back for now till i can get recon motor??
Regards
Martin
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Washing Machines problems?
Washing Machines
Machine just gone dead (15 months old). Power is getting...
Frigidaire Affinity ATF7000E Front Load...
The washer is only 2 months old and leaking water from...
Washing Machines
machine will only work at half pressure, can you help
Washing Machines
Kenmore Three Speed With Speed Control Automatic Washer...
Maytag SAV5710 Top Load Washer
Amana top loading washer 6 yrears old: 1st belt burnt so...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
