Question about Vacuums
I was vacuuming and part of a towel got sucked up, but not into the hose, and now it isn't working. I turned it off, unplugged it, and the hose still works with the attachments, it is just the base
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=833476
Generic problem for all Vacuums
Posted by melly6483 on July 25, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. 1st. I do not know the brand name and model # fr the vacuum so the next time include that type of information. So, if you removed the towel from the hose section then there almost has to be something in the powerhead and the power nozzle neck there would have to be a clog and you need to open the powernozzle and look for a clog of some sort in the power nozzle or the wand section that would block the flow of the dust and dirt to the canister section. Check your owner’s manual to see the trouble shooting section for unclogging your vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 25, 2008
Solution will not spray on carpet unless you use tools or spot spray also brushes are not turning
proheat 9300
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
Dec 07, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to unclog a bissell proheat turbo carpet cleaner
proheat 9300
Nov 24, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
A small hand towel was sucked into the wand and is stuck in the flexible tube. How can I get the towel out?
hello santafemiss if you have a wire hanger,
  1. untwist hook
  2. try to straiten the hanger
  3. make sure on end has a L like shape or a J
  4. jam the hanger into hose and spin it like you are using a fork for spaghetti
  5. and pull
  6. repeat steps a necessary
Nov 18, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No water sprays when I press lever on handle
proheat 9300
assuming the water works for the tools
Apr 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Ridgid shop vac is not sucking
Check the intake hose for a blockage. Attach the hose to the exhaust outlet and turn the vacuum on. If no extracted air is blowing out of it the hose is totally clogged up
Apr 10, 2010 | Ridgid 25648 Wet/Dry Vacuum
Vacuum will not pick up, the dirt just lays inthe bottom of the hose and does not get sucked up,i looked for aclog but there isn,t one
Are the filters clean? Is the brush roll turning? Otherwise check the dirt inlet by the brush roll for a clog. Pull the hose off from the bottom, is there suction there? If there is, then the problem is below where the hose is pullged into. If no suction, then there is a clog in the hose, take it off, (if it comes off completely), drop something like a heavy marble down the hose and see if it comes out or not.
Jun 16, 2008 | Dirt Devil Vacuums
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
I have an Electrolux Lux 7000. My son sucked a small towel into the hose, which is stuck inside the hose close to the attachment end. Can this model blow expel air so I can blow the towel out?
If it does, it should have a door on the top near the back. But if not then something like a plumbers snake or long needle nose plyers may help get it out.
Mar 10, 2008 | Vacuums
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
