Question about Samsung HLN617W 61" Rear Projection HDTV
No Power A few nights ago a couple of long thunderstorms and a lot of lighting strikes in our area, caused my TV and cable box no power through. I also discover my garage door opener also not working although it has the light on. Generally, there is a standby red light on the ON/OFF button, but this case I did not see any power. I checked the same outlet that I use all units, it does have power to my receiver and DVD player. Does anyone could provide me some hint to why no power on my TV? If the lamp is totally out, does it really have an effect on the light located at the ON/OFF switch?
  • TomTomPA Jul 27, 2008
    Actually I resolved the problem. As I speculated, the fuse was blown out. I had to replace a new fuse. That was a great experience.
  • 426 Answers
You could have gotten hit by a surege hope you had a surge protector, if you did just reset the breaker on it
Posted on Jul 25, 2008
Would replacing the main board fix my TV?
We can't predict what might have been happened during a lightning strike. If the TV is dead now; the main power supply regulator board [SMPS] board is fault. If so, you have to replace it first. then only we can get information about the condition of the main board. If the TV was connected to external Ariel or cable; before the lightning stroke; the possibility to damage to the main board too is there upto 80%.
In fact, if both of this boards are damaged, it might cost around 2/3rd of the total cost of a new TV.
The decision left to you. Do whatever you want.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 26, 2015 | Vizio 60" E601I-A3 Full HD LED-LCD TV
How do I fix my Vizio Television after a thunderstorm?
You TV was victim of power surge. You should take it to a qualified repair service to diagnose it, it it it can be repaired and if it's worth.
Curren flat panel electronic TVs are particularly sensible to power surge so it might be a good investment to use spike protectors.
Browse here
Top Rated in Surge Protectors
Jun 20, 2015 | Vizio E371VL 37 Class LCD HDTV - 1080p,...
Lighting strike 42 inch phillps tv mill not turn on
I would first look at the power supply board. it might be a removable fuse. unplug the TV first, remove the back of TV check the area to where the power cord comes into the TV. it should be real close to the power supply board.I have had a couple of quick fixes by just replacing the fuse. (that means it did it's job) if that doesn't fix it try to get the part # from the power supply board and check with Shop Jimmy.com for replacement board. (easy fix) take pictures of the back of TV with cover off and of the power supply board before u do anything. Leave the old board in place till the new one comes in. that way you won't forget where the cables went etc. Just be careful cause the dead board can still hold a charge so handle with care.
Sep 21, 2014 | Philips 42PFL5603D 42 in. LCD HDTV
Why wont my 42" vizio razor led hdtv turn on?
The TV's power supply has certainly got affected. Most probably some of the ground tracks might have got burnt along with a few components and this might require attention by a qualified service technician.
Jul 13, 2012 | LG 42LC2D 42 in. LCD HDTV
Thunder storm last night
have u made sure that the out let has power yet? if not check fuse box.
next, if has power to outlet, manually press power button not remote controll, after it has been unplugged for some time. view the back pannel of tv. and see if there is a fuse or fuse notification. follow manufactuar or owners manual instructions from here, google vizio support or call 888 849 4623 with model and info ready
Jul 13, 2012 | Vizio VW32L 32 in. LCD HDTV
Had thunderstorm Wednesday that hit the Pecan tree and ran into the ground striking the gas line an turning off electricity. I turned electricity on with TV on a surge and TV will not come on. The green...
Ur tv was plug into a power surge protector?Yes?Tries tv and those pay cables or satalites signals boxes unplug,replug it back about 20-30 mins later for those pay signals boxes to reboot and updated it softwares.Tv to do a resetting itself back to factory setting.The tv have 50/50 might work again.If not have to take parts and check for any can see plainly viewing damages.Than that ur tv causes and damges.Not.If u want to tries to save this tv.The first thing u have do the must change the tv power supply board first see if that will save ur tv,that the board where power a/c cord plug into it.If not tv must have to be change the main logic tv turner signal board too.That the board where it take in the tv broadcasting signal wire plug into it.80-90% these 2 boards are causes and take most of the power surges.U have some basic mechanical skills like take things aparts and putting it back togther?Yes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement or the tv main logic tv Tuner signal board too.
Aug 26, 2011 | Sanyo DP46849 46 in. HDTV
We had a thunderstorm last night, and the power went off and came back on a couple of times and now our Tv isn't working. The green power light stays on, but there is no picture on the screen. We...
The tv Tuner signal board it is shorted and dead.That the board where the tv incomming broadcasting signal cable plug into it.U have some basic mechanical skills like take things aparts and putting it back together.Yes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 12, 2011 | Norcent Technologies LT-3250/LT-3251 32...
No HDMI Output thru' receiver
you most likley blew a fuse . take it to a repair shop it you live in an area that has lot's of storm activitey you might want to look in to getting serg protection on your elect panel to save repairing other thing's in your home. thank you please rate mee
Feb 12, 2009 | Pioneer Elite VSX-91TXH
Samsung HLN617W 61" Rear Projection HDTV Logo
46 people viewed this question
Henry  Thomas
Henry Thomas
