Question about Samsung T509 Cellular Phone
Number pad buttons dead
A few months ago roughly half of the buttons became unresponsive.  It was intermittent, but now it's permanent.  I really like the phone and don't want to purchase another.  Any ideas are greatly appreciated.
Thanks!
  • 1 more comment
  • morriswz Jul 28, 2008
    I've opened the phone to access the buttons. The button is still a physical detent, not an electrical connection. Half the buttons are unresponsive. I'm unable to get under the next layer, it's all glued together. I'm not convinced it's a dirty connection. Half the buttons stop working simultaneously, when it is intermittent it's always the same group of buttons that either work or don't.
  • morriswz Jul 29, 2008
    the contact points are all clean and shiny. the non-working button contacts look exactly like the working ones.
    Thanks, I'm pretty sure the part has gone bad. Any ideas for a repair shop in the Oakland CA area?
    thanks again!
  • 928 Answers
Open up the phone then use an eraser over the contact points for the keypad. Most of the time the problem is because moisture affects the contact points on the keypad.
Posted on Jul 28, 2008
    Genius:
  • 1,689 Answers
Keypad contact, open the phone then clean the contacts using a regular pensil eraser, on the keypad, try to brush out the dust using a toothbrush or a small PC vacum cleaner
good luck
  • 1 more comment
  • marlon john madrid
    marlon john madrid Jul 28, 2008
    and if in case that after cleaning it you had the same issue, you may want to use a new number pad.
    the link below will give you the parts you may want to upgrade or replace.
    http://www.cellphone-repair-shop.com/GH7...
    marlon john madrid Jul 29, 2008
    thank you for clearing that out, it is just not a dirty keypad, the culprit will be the metal dome assembly, it is not easy to repair by hand, you have to have special tool for it, but it is replacable.
    refer to the link below for the part i mentioned.
    http://www.cellphone-repair-shop.com/GH5...
    it may be available in local cellphone part shops, plus you'll get free installation.
    have this part repaired or replaced, there is a possible crack on this part of your cellphone, it is either you get this repaired ot replaced, as i said earlier this is not easy to fix with out special tools
I have a 2006 Kia Sedona. Starting a few months ago, I would turn the key to start and nothing happened. No clicks, nothing. The dash lights would come on like normal while the key was turned. After...
check the clutch start switch or the park neutral switch operations
you need the clutch in to start and there wia switch there that may need adjustment
same for the auto park /neutral switches
check wires
Apr 25, 2017 | Kia Sportage Cars & Trucks
TV Rarely Starts
Check all the solder terminal at its main power regulator section circuit. Any loose solder terminal can poise this type of problem. Resolder all the suspected solder terminals by applying a little more solder. If you wish to get more details, check this site.
Apr 22, 2013 | Hitachi 32UX01S TV
Gauges stop working, engine won't idle
See the YouTube video on how to repair broken solder joints on your instrument cluster connector. This takes about an hour and solves a number of intermittent problems. I think it may be under "no start" problems.
Feb 18, 2013 | 1999 Dodge Caravan
94 chevy astro rough idle and surge when driving
check throttle body and check for codes
Feb 06, 2013 | 1994 Chevrolet Astro
TV will not power on
the remote button has change resistance... its a carbon film resistor on board.. cleaning
Dec 15, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Remote's menu and input buttons, and television Input button not responding
well the problem sounds like it could be the IR sensor on the tv or somthing in that circut that is failing or the EPROM chip that controls : Vol up/down , Channel up/down , Power on/off ,Menu , Input selection , ect... is failing, thus this will trigger the protection circut to shut the tv down. this kind of a problem only gets worse and can dammage other components if not repaired soon so it will need testing to determine the exact cause
Oct 13, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Standby problems
Yeah,
Press all the buttons at the same time, threaten to through it in the toilet, then give it a couple of agressive taps.
It works.
Really.
Jul 11, 2007 | Samsung Digimax A400 Digital Camera
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Samsung T509 Cellular Phone Logo
59 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
