Question about LG CU500 Cellular Phone
Ring tones not loud - LG CU500 Cellular Phone
    Problem Solver:
If your phone carries a removable memory card, sd or other, then u can create any ringtone at any volume.
There is a free application on the web, using your pc, called Traktor. Primarily it is a DJ tool or mixer but comes in quiet handy for upping the volume on ringtones.
All you do is put the track you want into the mixer, press play and record after setting the required volume,pressing stop and save at the end of the track and hey presto !!
Then just copy the track you saved over to your sd card and put it back in your phone.
After this, select the adjusted track, copy to phone and apply as ringtone.
And there you go.!
Hope this helps. It has for me loads of times.
Al.
Posted on Nov 27, 2008
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
My BB9000 is not loud enough. I selected the profile "loud" , selected the "classic ring tone phone", set the volume to 10 and I can hardly hear the ring tone. Thanks, Victor
Did you put your own ring tone on there? If so...it is not loud enough. I know this from previous experience. When you record one and drag into the mini sd card you have to do it very loud. You can use the recorder that comes with that phone and record one and then select it as the tone but make sure you get it close to the mike.
Nov 05, 2010 | RIM BlackBerry Bold 9000 Smartphone
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
It has low ring that i can not hear it ringing
The ring tone volume on the X1 is not very loud you will just have to choose a loud ring tone that will catch your attention. Have you tried putting both the phone and ring tone volume up by pressing the speaker symbol at the to of the screen and putting both sliders up full.
Jul 18, 2009 | Sony Ericsson XPERIA X1 Smartphone
How do I get a louder ring on my blackberry 8700
From profile on desktop choose Loud and activate - The megaoohone logo at the top of the homepage should now have a red outline.
Jan 23, 2009 | RIM BlackBerry 8700g Smartphone
My Nokia 6085h will not ring out loud.
there should be a volue control in the phone section of the setup icon turn that up
then if you didnt assign a ring to your groups, try asigning a different ring tone to each group and make sure the ring tones have a loud sound by playing them using the phone.
other than that, it shoud be a hardware problem with the speaker that needs to be replaced.
Dec 29, 2008 | Cell Phones
Won't Ring
check the settings in your phone book. this happened to my phone and all of the personal ring tones were set to vibrate. I don't know how this happened. I went into each contact and changed the ring tone to none and I am back in business
Sep 15, 2008 | Motorola Mobility W385 Cellular Phone
Message alert tone
hi there ,
             you have to enter settings , tone settings, then you select loud , then select loud details , you can change the message tone , the alert tones , the ring tones from there.hope this helps..
Simon
Sep 04, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Text tone motorola V3i
go to options ring styles... then for example your ring style is loud, then go to loud detail and there select the type of alert for messages. similarly it applies for all the other ring styles.
Apr 26, 2008 | Motorola Mobility RAZR V3i Cellular Phone
LG CU500 Cellular Phone Logo
59 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
