Question about Canon PowerShot A70 Digital Camera
Dead Camera is frozen open with the lens extended. Recharged batteries, no help. They want a fortune to check out at the camera shop. Any ideas?
  • citykity Sep 26, 2008
    I put the camera aside, & pulled out about a week ago. I used one of the three sets of charged batteries I had tried before, and the camera worked. I've only used it a few times since making this discovery, but when I use the flash it makes a crackling noise. (Kind of like an electrical current noise...). I hope it will continue to work ..I can live with the crackel : ) Thanks for your input!!!!
Have read of same problem from numerous users on the internet. One person said this may be caused by a twisted/jammed lens. Apparently the "telescoping" lens mechanism can sometimes jam due to a drop and/or from dirt that gets in the telescoping hardware. The solution that someone gave that I read about involved telling the user to try to gently twist and/or wiggle the extended lens parts counterclockwise to try to "unjam" them. Of course that would also require having fully charged batteries, etc, before you try that, since from my experience, low battery charge results sometimes in the lens not retracting (or extending) properly also. It's worth a try anyway, since apparently your camera isn't functioning properly anyway now with its lens extended. I have a problem w/my On/Off switch not working properly, and in checking w/the Canon USA website, they wanted a minimum of $87 to "start" to attempt to fix it (whatever the problem is), and required that I pay them that much "up-front", and that I agree to whatever it then would cost in toral. I backed out and went and bought some new cameras instead, since I felt that was way too much to invest in my A70, that's already 5 years old now. Good luck w/your extended lens problem.
Posted on Sep 25, 2008
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
Canon digital camera no power
Power issues are common in anything electronic, including digital cameras.
A digital camera can fail to power up for a number of reasons, but fortunately, they're often related to the batteries, making them minor in nature.
If your digital camera won't turn on, check several things to diagnose the problem.
Battery Life
It is common to try to turn on your digital camera, only to see that it will not power up. A highly likely cause of this issue is the power in the battery or batteries. If you've used the batteries for an extended period of time, mistakenly left the camera on or are using old batteries, they may simply be dead. Remove the batteries from your digital camera and test them in another electronic device, such as a remote control. If the second device won't turn on, the batteries may need to be replaced or recharged. b> Battery Position b> Though it sounds like a mistake that is too simple to make, it's easy to insert the batteries incorrectly into a digital camera, especially if it's new and you're unfamiliar with it. When the batteries are put in backward, the digital camera will not power up, leading you to assume there may be a graver problem. If the camera will not turn on, open the battery compartment and verify that they're in correctly. If not, rotate them appropriately, close the cover and try to power up the camera. b> Lens Track Problem b> Depending on the camera bag you use, the camera may occasionally and accidentally get turned on while it's in the bag. When this happens, the lens may begin to extend outward from the camera, but get blocked by the camera bag. All this can happen completely unbeknownst to you, which can lead to the camera not turning on the next time you need it. In some cases, the lens can get knocked off its track, which can result in your camera's power light illuminating once the camera is turned on, but the lens not emerging from the camera body. In more severe cases, the lens' repeated attempts to emerge while stuck in your camera bag can burn out the small motor that operates the lens. When this is the case, take your camera to a repair shop and have a technician look at, and fix, the problem. b> Defective b> Although not likely, there's always a chance that when you buy a new digital camera and load it with fresh batteries, it won't turn on. If this is the case, the camera may be defective in some way. Because new cameras are covered under warranty at many shops, take the camera back to the shop and explain the issue to a technician. Hope it helps.
Jan 24, 2013 | Canon IXUS Cameras
Optio s6 frozen
By recharging the battery, and then restart the camera, it may just work.
Because you were working on a movie in the camera at the time it quit, that file may be corrupted.
It would be interesting to see what has happened on this problem.
Jul 22, 2008 | Pentax Optio M20 Digital Camera
Camera frozen
try removing the memory card first then turn it on ...
see what happens
the problem maybe with your card and not with the camera
Nov 16, 2007 | Kodak EasyShare C360 Digital Camera
Frozen Camera
Dont touch the lens leave it out. Recharge the battery and re try or a fresh battery. It is possible the battery is not fully charged or has a dirty bottom end plate Contct the makers tech support team
Jun 24, 2007 | Konica Minolta DiMAGE G400 Digital Camera
Non-functioning camera
open the unit. look for anything electrical disconnected from sloppy factory
May 19, 2007 | Kyocera Finecam S5R Digital Camera
Sudden shutdown
Hello Sandi, I think there is a problem with lens and it will not be fixed otherthan Canon. It better to go Canon shop. thank you.
Jul 24, 2006 | Canon PowerShot A85 Digital Camera
Canon PowerShot A70 Digital Camera Logo
104 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
