Record from Panasonic Omnivision PV 4461
First VCRs are hard to come by these days!
I have a Panasonic Omnivision that I recently aquired at a Salvation army to play a few tapes and record off my DVR. The tapes are fine, but I can't get the darn thing to record. I have no remote- I'm trying to program a universal one, but the VCR is so old...
Anyone know how to get the record button to work? Thanks!
5 Suggested Answers
  • 4234 Answers
SOURCE: Re: Model PV-4523S
The problem is that the "idler" assemby has gotten slippery. This is either a rubber tire or perhaps a gear that is driven by a belt inside the machine. In either case, this is a simple repair and is common as machines age. This should be a $75 repair including parts. The pinch roller (rubber cylinder) is what pulls the tape across the heads in a steady fashion and has no role in keeping the tape inside the cassette. This is handled by the idler assembly and works for FF/REW and PLAY. Also, a cleaning tape will clean the heads but not effect the pinch roller.
Dan
Posted on Jul 30, 2008
  • 520 Answers
SOURCE: VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Posted on Oct 11, 2008
Grubhead
  • 5259 Answers
SOURCE: Have PV-8401 VCR plus Omnivision VHS but missing
Ok there's a lot!
1005, 1021, 1043, 1085, 1160, 1161, 1210, 1218, 1219, 1242, 1248.
Please bear in mind some codes will operate some functions but not all, you might need to check different operations before you get the right one.
Posted on Oct 14, 2009
Grubhead
  • 5259 Answers
SOURCE: Video on my Sony VCR (SLV-780HF) goes gray after playing a tape a few seconds. What could be the problem?
The only real cure will be to clean the video head. If that doesn't work then I'm afraid that whatever recorded you EP mode tape was not set up well tracking wise. So other machines struggle to track the tape. Some VCR's will only playback SP or LP tapes and don't have EP mode. In which case you should check to see if these VCR's can play the EP tape and if they can't find one that can.
Posted on Dec 09, 2012
Manual for vcr model PV-V4022
The Panasonic website might have a free PDF of that.
Oct 09, 2014 | Panasonic Model Pv-v4022 4 Head Omnivision...
How to set up my old vcr to a panasonic tv and get it working.
The VCR should set itself up. But if it doesn't have a digital tuner then it will not find any stations. You will just have to cancel that bit and do the rest. You can connect a set top box to the scart socket 2. If you want to record you have to set the timer manually and set it to record scart 2 not a channel. If the VCR has PDC set it to off.
Dec 05, 2012 | Panasonic Pv-v4530s Vhs Vcr Omnivision
Panasonic omnivision pv 4651 no video signal but audio is fine
If you mean during playback, then all you need to is clean the Video Head with Servisol Video 40.
Jun 14, 2010 | Panasonic PV-4651 VHS VCR
Have PV-8401 VCR plus Omnivision VHS but missing remote. I have a universal remote bu don't know what code the VCR is
Ok there's a lot!
Oct 05, 2009 | Panasonic PV-8401 VCR
Panasonic VHS Model PV-4461 keeps blowing fuse. Problem is strictly limited to the power circuit (Ref # 1000 series). All capacitors, resistors, etc look OK. Any ideas?
is the power circuitry a SMPS (switching mode power supply)? it's a bit complicated to troubleshoot one of these. Google it if you want to service it yourself, there are some DIY guide out there. Goodluck!
Aug 17, 2009 | Televison & Video
Panasonic omnivision PV-V4021
Read the book. ........... Get one.
Apr 17, 2008 | Panasonic PV-V4021 S-VHS VCR
Lost the remote, manually need to access Menu button
VCRs since the early '90s have limited function with the machine located controls, and a remote is necessary to get into most setup options, probably including the channel add/delete. Many VCRs do have an auto program mode which searches for active channels, but I'd guess this also is activated via remote. A universal remote which specifically has the capability of performing the advanced functions is probably available. Look here for an exact http://www.electronicadventure.us/panasonic.htm Part number is VSQS1418 according to this site for PV4501.
Aug 27, 2007 | Panasonic PV-7661 VCR
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Electro Med Services...
