Question about Dell Dimension 3000 PC Desktop
Firewall - Will Not Turn On
Installed MS "Care - Live-One" After it was installed, I found the firewall turned off. Attempted to turn-on through the Live-One features. It would not highlight the on button.
Found the same problem when attempting to turn the firewall on through "Settings / Control Panel / Windows Firewall" i.e. the "On" button is shaded and inactive.
What gives and how do I reinstate the firewall before going on-line ?
  • 300 Answers
How do i bypass firewall to install a program
Turn OFF the Firewall in Control Panel then turn Firewall ON after you installed the program.
Jan 23, 2013 | Toshiba Satellite C850-BT2N11 Laptop
Error 0x8007064c when installing windows live messenger on windows 7.
How to enable Windows Firewall when you receive an error code 0x80070643 or 0x800706d9 during Windows Live Essentials installation
Symptom:
Users are reporting installation issues when installing Windows Live Essentials.
You might receive one of the following error codes during the installation process: 0x800706d9, 0x80070643
Cause:
When Windows Firewall is disabled, installation of Windows Live Essentials could fail in some cases, because some Windows Live Essentials components require Windows Firewall to be enabled in order to install successfully.
Background information:
Windows Firewall is a software based solution to filter incoming and outgoing traffic of your computer or network. All traffic to and from your computer pass through Windows Firewall, which inspect all types of traffic and either allow or deny traffic depending upon the firewall settings. Microsoft includes the built-in firewall feature in all latest Windows operating systems like Windows XP, Windows Vista and Windows 7
Resolution Steps:
To enable Windows Firewall in Windows Vista/7 please follow the steps:
Note: To use this feature, you will need to be logged into your computer with administration rights.
1. Click on Start button and then click on Control Panel option.
2. In Control Panel click on System and Security link to go next.
3. Click on the link Windows Firewall
4. On left side panel, click on Turn Windows Firewall on or off
5. Select Turn on Windows Firewall for all (Domain, Home and Public network)
Jun 11, 2011 | Microsoft Computers & Internet
I cant get past the routers firewall for certain programs. How do I allow these exceptions? Help!
Your computer has the firewall installed in it, you will need to turn off or configure your firewall settings in your computer, to do that if using windows XP: Start/Control Panel/Switch to classic view/Windows Firewall, turn off firewall.
Windows Vista/7 Start/Control Panel/Windows Firewall turn off firewall. Follow these steps good luck.
Mar 25, 2011 | Linksys Wireless-G Broadband Router
I use a HP Pavilion dv6000 with Vista SP1. When I try to install the Vista SP2 I get every time the erro code 800B0100. I never found a solution to that
the most common cause of this is your firewall - you need to disable it whilst installing the update.
depending on the security software you have installed the options are different.
If you are using Windows Firewall: start, settings, control panel Security Center - click on firewall and set to off.
Important - remember to turn it back on afterwards.
If using 3rd party software turn the whole thing off whilst installing the update.
Please let me know if this works for you.
Dec 17, 2010 | Microsoft Windows Vista Home Premium with...
WebRoot antivirus & antispyware seems to turn off Windows firewa
click on start, then go to control pannel...you should see windows firewall options just double click it,,the open it make sure click on the option button "on (recomended)" this will turn your firewall on permanently
Jun 06, 2010 | Webroot AntiVirus with AntiSpyware &...
On my BB 8700g 4.5 when I try to open SugarSync I get this message: "the application sugarsync has attempted to open a connection to a location inside the firewall and outside the firewall which is not...
When you are trying to open a third party application on the BlackBerry smartphone, the following error message is displayed: The application {application name} has attempted to open a connection inside the firewall and outside the firewall which is not allowed by your IT policy. This issue is caused by a restriction in the BlackBerry smartphone's firewall.
To remove the firewall restriction, complete the following steps:
  1. On your BlackBerry smartphone, go to Options > Security Options > Firewall.
  2. De-select Enterprise Messaging.
  3. If this does not work, turn off the firewall by selecting Disable in the Status field. If you are not able to turn off the firewall, contact your IT Administrator as there is an IT policy restricting your firewall settings.
Hope I helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 10, 2009 | RIM BlackBerry 8700g
Start up will not retain memory for fire wall setting.
Make sure you haven't installed a third-party internet security suite that includes a firewall. You should only use one firewall on your system and some third party firewalls automatically turn the windows firewall off. But your security center should show that you are protected by a firewall, nevertheless.
This behavior can be an indication of malware installed on your computer...
I recommend you go to windows update and make sure you are current with all critical security updates for your system, then go to www.malwarebytes.com and install their AntiMalware software. Scan your system and fix any problems it detects.
Then see if your system retains the firewall settings.
I thought there was a MS knowledge base article on this that had something to do with sp3 and a bug fix but I can;t seem to find it right now...
If I locate it I'll post back with a comment...
In the meantime, if those first two suggestions don't turn anything up, I'd run chkdsk on your system and see if it finds some file corruption.
See this article and this one
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 21, 2009 | Dell Dimension 8400 PC Desktop
Help with turning firewall off
Start Button/Control Panel/Windows Firewall/Disable
For router firewall, follow your router's configuration instructions.
Oct 19, 2008 | Computers & Internet
Says its ready till i try and print
Dell printer drivers try to 'phone home' with Ink usage stats .. even if you select 'no' when asked, they still try to access the Internet ..on install the driver modifies Microsoft Vista Firewall settings to permit this ...
So if you recently installed a non-Microsoft Firewall eg. ZomeAlarm your print driver will be denied access to the web and will refuse to print.
Note that 'deny' is different from 'time-out' ... to test turn off your wireless (or remove the ethernet cable) and ONLY THEN turn off your firewall - if it now starts printing you have your solution (go into Zone Alarm and Enable all Dell & MS print related software access to the Internet).
DO NOT browse the web with your Firewall turned off !!!!
Oct 14, 2007 | Dell Inkjet 720 Printer
Dell Dimension 3000 PC Desktop Logo
64 people viewed this question
Alun Cox
