Question about Canon Pixma iP6000D InkJet Photo Printer
It won't print.
My printer won't print. Thought it was the driver so I deleted the IP6000 from the printer utility and reinstalled the driver from the CD that came with it. (did I do that correctly?) Then tried a simple text doc. and it won't respond. I was able to print a head alignment test from the utility though, so can't figure why nothing else gets through.
  • floridahoghu Dec 16, 2008
    my cannon pixima ip6000d will print from a memory card, but it will not print from the computer anymore not really sure why it stoped it keeps saying printer offline so i went back in and set it as online still no help rebooted the program and still no help... does any one know whats going on help would be much app.
Have you got the IP6000 set up as the default printer?
Posted on Sep 06, 2008
Dell printer will not complete task. If printer is uninstalled then reinstalled it will print one time but doesn't complete the task on the "printing screen". I go to the printer window...
Hi Bill,
Have you tried the printers on another PC?Please do.
  • Whats the Operating System on your PC?Do the printer drivers correspond with that Operating System?If not,download the corresponding drivers from this dell support site. This you select under compatibility.
  • After uninstalling the printer,disconnect fully and unplug from power.Reboot your PC before installing the printer again.
Hope this helps.Thanks!
Nov 01, 2011 | Dell V305w All-In-One R840635AU InkJet...
I have a Lexmark S504 wireless multifunction printer. I can print a test page but a can't print anything from any application. The Windows print page window comes up and if you click OK it appears to...
It could be a printer driver issue. Please follow the steps below to fix the problem.
First, clear the print queue from any stuck print jobs. You can do the steps mention - going to Services and stop the print spooler, delete the files in the spooler folder and then restart the service.
Second, delete the existing Lexmark Interpret S405 printer driver. On your computer, go to Start menu > Programs > Lexmark > Uninstall. After the uninstall process, reboot your pc when prompted.
Third, visit the Lexmark website to download and reinstall the Lexmark Interpret S405 printer driver. Select the version of your Windows operating system. Download and execute the file. Follow the instructions on your computer screen.
After the reinstall process is successful, try to print again to verify that the problem is fixed.
Sep 07, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I cannot uninstall my Lexmark printer model X 4580 because I have to delete print job. How do I do this on my new Macbook/Pro?
You can uninstall printer driver from library folder.
Go to system preferences and delete driver from Library /Printer .
Delete that folder then your printer driver is will uninstalled then reinstall the driver if you want to use it again.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 20, 2010 | Computers & Internet
Dell 926 does not print...."communications with computer and printer not present"....tried reinstalling driver....no luck....Jeff
hi jeffhup,
you can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
Oct 11, 2009 | Dell 926 All-In-One InkJet Printer
Dell 942 all in one printet wont communicate to dell dimension pc
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
You can try these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
good luck. :)
Aug 30, 2009 | Dell 942 All-In-One InkJet Printer
Stops after printing 1 job
A reboot likely fixed this problem already, or at least freed up the corrupted print job enough to be able to delete it out of queue.
However, if this is a reocurring problem, a corrupted printer driver could be the cause. Try reinstalling the drivers.
Jun 09, 2009 | Lexmark X6170 All-In-One InkJet Printer
HP1315 doc's in queue will not print or delete????????
Dear Ralph
plz check ur printer cable from both end if they are connected properly or not , if the cable connected then uninstall the printer driver and restart the system . After restarting the system then reinstall the printer driver with proper port configuration setting (For USB Cable - Port DOT4 or USB & For Com Cable Port LPT or Com) then after installing restart the system again and when the system start then check by giving print .
Jun 08, 2009 | HP PSC 1315 All-In-One InkJet Printer
Image and text printed multiple times and are overlapping
Is the R1800 the only printer that you have on ythis mac?
If it is make sure it is directly connected to your mac via a USB or Firewire cable.
Trash epson folder from Mac HD-Library- Printers
Delete Epson printer utility from Mac HD- Application folder( if you have both delete both icon.
Under prnter setup utility delete the r1800 printer
Go to finder click on file the find, type com.apple.print, if it find anything drag it all on the trash, it will not disappear from the window ( the prefs and . cache files)
download the latest driver for your r1800 from epson website
epson12113.dmg - 10.3MB - posted on 12/20/
then reinstall it, after reinstalling try to readd th printer and make sure under print using it will say Epson SPR1800 series. If you see guten print/ that is a third party driver. dont use the gutenprint. then try to print, update me for the outcome
Apr 08, 2008 | Epson Stylus Photo R1800 InkJet Printer
Can not clear the print que
Follow these steps to resolve the issue. Step one: Delete the print queue Open Print Setup Utility located in the Application/Utilities folder. Double-click your printer in the printer list to open the print queue. Click the Stop Jobs icon. Click to select the document, and then click the Delete icon. Repeat the steps for all the jobs in the print queue. When the print queue is empty, click the Start Jobs icon. A message appears: No Jobs Printing . This indicates that the queue is clear. When you have cleared the queue, retry your print job. If the procedure has not resolved the issue, repeat steps 3 and 4. If the issue still persists, continue to the next step. Step two: Remove the printer from the list Open Print Setup Utility , located in the Application/Utilities folder. Click to select the Photosmart icon. Click the red X to delete the printer from your system. Close all open windows, and restart your computer. Step three: Add the printer to the list Open Print Setup Utility located in the Application/Utilities folder. Click Add . Select the printer that you want to add, and click the Add button. After a few seconds, your printer appears in the printer list, and your printer is ready to print.
Sep 13, 2007 | HP PSC 1410v All-in-One Printer
Canon Pixma iP6000D InkJet Photo Printer Logo
78 people viewed this question
old marine
old marine
