Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool top-load washer
I tipped the washer over to replace a stabilizing pin that fell out and tried to find my (missing) socks. I can see small clothing articles between the metal colander basket and the plastic drum. How can I remove the agitator or the plastic lip piece that joins the metal and plastic drum? Do I attempt to remove from the bottom or the top?
  • Laura911 Jul 29, 2008
    I managed to get the washer apart by taking the top off and the agitator out. Replaced the stablizing pins, cleaned the outer drum and the fabric softener dispenser but have not found my socks! Thanks for the tip. I don't have that wrench and I'm not all that attached to my socks so I'll leave it be for now.
  • Anonymous Mar 27, 2014
    Plastic seal around drum broke into pieces
  • 868 Answers
From the top and if you dont have the spanner wrench to remove the tub you are headed for a much bigger problem.Note:the spanner wrench ranges from $29.95 and up if you can find one less grab it and re- post this problem and i'll take you through the repair .
Please rate This !!!! Thank you!
Posted on Jul 27, 2008
When we do wash and small items like kids sock, etc. they are somehow getting into the pump section when it is draining, what can i do?
There should be a drain screen between the basket/tub area and the drain tubing. Make sure the drain screen is not missing or doesn't have any holes in it.
Dec 28, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Kenmore top loading washer. While moving it into the house, it made a loud sound and a small copper pin fell out of the bottom. Does anyone know how to put this back in place?
That pin is a pin used to move the washer (secure the drum) and is not used when in normal operation. There are 4 total that should be removed. They are stored in little cups on the legs, and likely fell out of the cup.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 10, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool top loading washing mchine will not drain
If you can get any panel off of the dryer you will see a leather or rubber joint that connects to the pump. Sometimes the socks that go missing float over the top of the drum inside the washer and get caught in the pump. If the pump joint is not broken you should see it bound up or kinked. Depending on your washer you may be able to remove the drain tube and fish out the blockage.
May 27, 2009 | Frigidaire FWSB5700DS Top Load Washer
Washer fills and washes ,stops but will not advance to spin cycle
if washer will not drain or spin !! , try this solution , 1 ) open washer and at the bottom locate a small DRAIN MOTOR PUMP , is usually clogged with lint & debri , take it out , clean it , replace and try again , let me know , AJ
May 22, 2009 | Whirlpool LSR5132PQ Top Load Washer
Refrigerator door fell off.
Fridge fell off in my hand. I understand the idea of how it works on a lower and higher metal pivot. The pivot closest to floor seems to be missing a washer, screw or nut. I need an illus of what may be a missing part. Then an idea of how the door is lifted onto said pivot- With Ease!!
Apr 25, 2009 | Refrigerators
Nothing happens after filling up
The missing pinis more than likely your problem.
Take a pencil or small screwdriver and insert into the lid switch hole and try the washer.
If it works, replace the lid pin.
If not, replace the lid pin AND the lid switch.
Apr 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Small earrings fell into holes on bottom
if they fell through those small holes doubt you'll find them something that small would probably be pumped out and down the drain ..if you haven't used washer since may be lucky enough to find them in pump but doubt it pump is pretty strong and can handle almost anything except socks and thongs
Sep 11, 2008 | Estate TAWX700JQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal De
