Question about iLO (2 GB) MP3 Player
Same problem I have the same problem, the screen keeps flashing but don?t let me go in to the music setup. I already spin the back of the battery and it doesn?t work for me
  • 1 more comment
  • klucky4791 Jul 27, 2008
    my ilo is also constantly flashing and it wont let me get to my songs. I changed the battery and hooked it up to a cell phone charger like it was suggested, but it didn't fix it. I even redown loaded new songs and that didn't work either. Help.....
    klucky
  • aicfan1 Jul 29, 2008
    My Ilo screen is also flashing but won't let me access the menu or music files. I've also changed batteries, checked for updated driver, uninstalled & reinstalled the software but the screen still flashes. I've tried holding down buttons, hoping there's some combination to reset it, but still it flashes. I've even deleted songs. I'm not over capacity. I emailed the support address listed on the manual and the email came back as undeliverable. If anyone figures this out, please let me know. Thanks
  • hiropete Aug 01, 2008
    When I turn on my MP3 the ILO logo comes on but none of by buttons work. Also the support telephone line is no longer in service and customer support email address does not seem to work either.
Yeah i encountered that problem also. what i did is i bought a regular cell phone charger from a cheap store that matcher the link cable and hooked it up to the mp3. the charger will make the mp3 player turn on by force. it wont let it cut off. i really dint start having this problem until i had put 124 songs on my mp3. i believe its a flaw in the design.
Posted on Jul 26, 2008
Tv cable and dvd lights keep flashing and tv doesn't get signal
The remote is in safe mode, remove batteries and reinsert batteries while keeping the button 2 pressed.
Aug 04, 2012 | Logitech Harmony 200 Universal Remote -...
Twister Mania start up issues
Make sure to run the Kinect setup and calibration in the Xbox 360 Dash. Move all the way to the right and select kinect settings. Run the setup and follow the instructions there. Make sure to have a Kinect setup card handy. (comes with games.) This should help with any calibration issues. If that doesn't work, try signing in with a different account, or doing an xbox live sign in test.
Jun 01, 2012 | Majesco Twister Mania X360 Kinect
When turning n the cruz tablet, the word cruz pops up and goes away. then cruz flashes
First don't worry too much you're just stuck in a loop or have bad firmware (most likely). The fix is probably going to be easy but you have to do some things. Just follow the directions I give and that Velocity gives and you should have no problems in about half an hour.
Take out the top SD card. Put in in your computer or an adapter that goes to the computer.
Go to the cruz website and download the current firmware (http://cruzsupport.velocitymicro.com/ics/support/KBAnswer.asp?questionID=814).
Even if you have updated the ROM something could have happened and it could be corrupted so replace it. Put that firmware on your sd card. Do not extract the zip file. Do not change its name. If the name changed (like if it has (01) at the end) delete the old file you downloaded and change the new one back to the old name.
Eject your sd card when you finish and put it in your tablet.
Press the top power button and the up volume button at the same time. Continue holding. You will see cruz but dont stop.. it'll flash kinda and it'll still say cruz.. keep effin' holdin'...
the robot shows up: you win! let go relax give it some time to freshen up. Have a cup of coffee and let it finish. Everything will be tidy and new when it's done.
the robot doesn't show up and the same thing that's been happening happens again: try pressing reset when it turns on (paper clip in that hole youll feel a button when you get it right). Keep pressing it the whole time it has power to try and get a hard reset. Do it like 2 or 3 starts and fails just for good measure.
then try to flash again (power and volume up).
if that doesn't work pull the back, unplug the battery and wait 30 seconds to a minute. plug it back in and try flashing the first time you start up. like don't press power hoping its going to turn on now. It won't. You have given it a clear quick access memory which may let you get to the point where you can flash without failing.
IMPORTANT: On the first time after the battery is plugged in hold power and up volume together and keep holding. This is important. If you press power it will recurrupt the RAM and you made the back lose and unplugged the battery for nothing.
If that doesn't work.. well it should. You're stuck in a loop that you should be able to pull out of. Go back the the beginning and make sure you have the new file you downloaded and the name is correct (its on the cruz support website).
If that's all done properly try the battery thing one more time. If it's still failing don't give up.. give it hell. I was stuck in a bad one going strait to white screen only being able to shut it off by pulling the battery and I was able to get it to flash (took about 30 tries). For the trying at this point you don't have to pull the battery just keep starting it with power and volume up pressed.
As long as you're not staring at a black screen you should be able to fix this.
Good-luck!
Dec 07, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
Time light keeps flashing constantly but time was correct. Tried relacing backup battery but still flashes. Does that mean replacement battery is bad or is it something else?
It is like you are in setup mode. Or maybe some button are not released (button failure)? After correct time input, it must have some setup button for going up from that flashing mode (OK, mode, setup... button, depend on model). Battery is bad when you release battery, disconnect from power line and it don't hold time.
Aug 24, 2011 | Audio Players & Recorders
How to fix not working touchscreen? Do i have to replace it?
The Samsung Q1 is a hybrid, ultra-mobile, touch-screen device that is basically a very small tablet PC. It features a 7-inch screen, weighs a mere 1.7 lbs., features a Windows operating system, doesn't have a built-in keyboard, and comes in a variety of configurations. The Samsung Q1 doesn't offer outstanding battery life, but you can make some moves to boost your computing time.
Dim the Screen
Dim the screen brightness. Four programmable application-launch buttons occupy the right edge of the Q1. One of these, the menu button, calls up frequently-used controls, including screen brightness. Reduce the screen brightness as much as you can, as it's one of the best ways to extend battery life.
Close Power-hogging Apps
Close applications and browser windows when you're done with them. Too many open programs drain the battery. Beware power-hogging apps. Watching a video or listening to music on your Q1 drains your battery life much faster than just using Microsoft Word or checking email. Turn off the Wi-fi networking when not in use. The built-in Wi-fi searches for a network when you're not connected, which drains battery life.
Properly Caring for and Feeding a Battery
Unplug the Samsung Q1 after the battery is fully charged. Leaving your Q1 plugged in 24/7 leads to some discharge from the battery. Consider buying a bigger battery. A 3-cell battery comes with most configurations of the Q1, but you can also buy a 6-cell battery to double the battery life.
Room Temperature is Best
Don't expose the Q1 to harsh conditions. Keeping the device in a blazing hot car in direct sunlight harms your battery life. If you use your Q1 in conditions above 95 degrees Fahrenheit, you can permanently damage the battery. Cold conditions don't harm the battery in the same way, but if you leave the Q1 in the cold, let it warm to room temperature before you use it.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | Samsung Q1 Tablet PC
I have put a password on the phone & iv forgotten it. Is there anyway i can remove the password or get the password sent to me thru a email so i can keep all my photos & music....?
Download Zune software from HERE . Now sync the contents ( pictures , music ) . If you are connecting the phone first time , it will go through the relationship setup , here make sure you select sync all ( for music , pictures , videos ) . This will sync your contents automatically to the computer without asking you . If you have already setup your phone with zune , then click on " settings " , select phone and change the above there .
Now you will have to hard reset the phone . Here is how you do it
With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons. While holding the volume buttons, press the END/POWER button briefly and then release it. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons. Follow the instructions on the screen .
Once you hard reset , you have to start over again and then connect the phone back to zune and there you go , you are back to square one .
Thumps up if this works ...:-)
Aug 12, 2011 | HTC 7 Mozart Cell Phone
My pcg-fx220 vaio laptop has what looks like battery 1 flashing yellow light. I start it up but it doesn't get past the sony start up screen the little light just keeps blinking. It's plugged in so...
Take out the battery, plug it in turn it on, if the problem is the same unplug it. Turn it over and remove the access panel from the bottom. There you should find your RAM if you have two RAM modules installed remove both and replace them one at a time with the power off. So insert one and power on computer if the same result as before, remove it and insert the other RAM and power it on again. Also look to see if your CPU fan is spinning. If your fan only spins for 5 to 10 seconds and powers off one of three things are bad, either your CPU, GPU, or Motherboard are bad or damaged. It might turn on here or there if this happens it's probably your GPU. Hope this helps you.
Jun 28, 2011 | Computers & Internet
Sandisk u3 cruzer micro usb device stopped playing when put in car stereo. It was playing fine but now nothing my car stereo say's it's reading the device but thats it
You might try plugging it back into your computer, and formatting it. If you don't know how to do that, pull up the screen right BEFORE you would open it to copy music to it, right click on the flash drive, and click format. Format it with whatever the default format is shown (probably FAT32) and then copy your music back onto it. If that doesn't work, let me know.
May 05, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
The date will not stay set. Every time we turn the camera on it opens with the date screen. We set the date and it then goes into shoot mode but the date is not set. All pictures are stamped with the...
to keep the date on, you have to leave the camera off with a charged battery for 24 hous to charge the inner battery that keeps date on. If this doesn´t solve the problem then is because the inner battery won´t charge anymore, but it will take pictures as normal without the date. To avoid this don´t leave the camera too long without use or with a worn battery.
Oct 04, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
iLO (2 GB) MP3 Player Logo
27 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
