Question about Zenith R57W46 57" Rear Projection Television
Hissing popping sound
My tv just started making this sound the picture seems to be ok but i am concerned with this sound.
i can not locate it after taking the back off?
any suggestions
thanks
hank
  • 2 more comments
  • yogibear910 Jul 25, 2008
    the popping came from the middle crt i guess you call it
    i have the back off trying to pinpoint the sound and it made
    the noise to the left and above the splitter
    hank
    it came from above the circut board if you got the picture
    it was just left of the yellow plastic with the red dot on it
    kind of a purple blue hue
    let me know if you got the pic
    hank
  • yogibear910 Jul 26, 2008
    very helpful person
    thanks
  • Anonymous Oct 26, 2008
    Hello there. Just found this post and decided to ask for some assistance. I have a very similar problem with my Zenith Z56Z95D8. Recently, the picture went black...still had sound just no picture. Was told to replace the HV module board(part# 9-1674-03). As soon as I did this, the tv worked fine for a couple days. Now, to start tv I need to hold in the power button for it to turn on. When it come on there is a distinctive electric "clicking-popping" sound being made and the picture has a "electrical interference" at the same time as the sound. I can definitely trace the sound to the part where the HV module wire plugs into the bottom of what I would call a splitter block. There are (3) additional wires that go from this "splitter block" to each of the CRT's. The id sticker for this part is # A-17813-01. Is this the culprit part? What is this part called? Where to get a replacement cheap?
    Hopefully this helps Hank also with his problem...sounds almost identical.
    Thanks Alot for any assistance, don't have $$$$ for a new tv.
    Steve
    brnltjo@embarqmail.com
  • Zenith Master
  • 8,617 Answers
It sounds like the flyback or the HV splitter those are the two items that will hiss. It should be coming from the area where the flyback is. thats a large transformer with a large red wire coming out of it going into a Splitter that will have 3 additional large red wires each going to the three CRts. Let me know if you need the part numbers and where to get the parts with free tech support so you can easially install them yourself.
Posted on Jul 25, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jul 25, 2008
    The HV lead going into the CRT may need to be resealed. But without touching that red wire try to determine if its coming from up high on the crt or down near the circuit board of the CRT. Just dont touch the red wire alot of voltages are present in that large red wire.
  • Sonny Berry
    no i didnt get the picture, you can send it to my email which is slinteriors@yahoo.com if youre having a hard time posting it here.
  • Sonny Berry
    Sonny Berry Jul 26, 2008
    youre quite welcome. I will help you get it fixed.
I have a 2005 Pontiac that makes a hissing noise underneath the car. you can turn the car ignition on without fully starting car and it still makes hissing noise then stops.HELP!!!!!
There is a distinct sound that has a hissing component when you first turn on the key. It will last a second or two when the key is turned to the run position. When the engine started the sound will return and continue to produce the noise so long as the engine is running.
A relatively low noise is normal. If you are concerned check other like cars for the loudness level.
how to check your fuel pump
The pressure regulator on the fuel rail can also produce a sound when the fuel pump is running. The regulator is under the hood and any reasonable noise would not be a concern, A clicking sound is also normal throughout the fuel system when the engine is running created by the fuel injectors cycling.
Dec 28, 2015 | Pontiac Cars & Trucks
Kp 61HS30 TV Had the tv since 2002. been a great tv. Just recently it started making a noise when you turn it on. Noise fades away after about 10 seconds. Noise kind of sounds like a dvd player trying...
If you locate the audio board, check for dried up electrolytic capacitors and dry joints around the output IC itself.
That should fix your fault.
Nov 27, 2010 | Sony KP-61HS30 TV
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
TV goes blank - no sound or picture
Sounds like a bad capacitor or two in the power section. Do you hear a hissing sound also?
Nov 18, 2009 | Pioneer PRO-510HD 53" Rear Projection...
Sony Videoscope TV continuous hissing sound from back of tv and picture seems to be getting worse model kp 46c36 year 1997 once tv has warmed up hissing sound stop but picture still a little iffy
Ur high voltage is dying,the FBT,the flyback transformer is the prob.the big block of plastic with a red wire a with a cap hook to the CRT(crt tv).
Sep 29, 2009 | Televison & Video
Picture is ok hissing sound in rf connectoin
Yes, change the tuner and make sure that all ground are well connected.
Jun 16, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
Speaker hiss with TV only
Hissing sound caused by input section RCA cables defected grounding maybe loosed or the RCA cables are defected already replaced it with new RCA cables so hissing sound is gone.
Hope it may help you;
Regards;
VOTIT
Oct 11, 2008 | Denon DHT500SD System
Sharp TV Problem
everythin ok that what you hear is work of oscilator from tv set
Feb 04, 2008 | Sharp 27C-240 27" TV
Zenith R57W46 57" Rear Projection Television Logo
196 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
