Question about Microwave Ovens
Where is the light bulb on JES738WJ GE microwave oven? I need to change it as it burned out. Thanks.
Took cover off unit to expose bulb. However, was not able to remove bulb by pulling, or unscrewing. Guess the entire bulb "unit" must be replaced.
Posted on Jul 26, 2008
Changing interior light bulb on GE jes1289sk
I have had this trouble before but with a different model. There may be a plastic screen inside the microwave that will just pop off exposing the bulb. Now all you will need to do is to find out what type of bulb you will need to change the other bulb. I hope this made things easier on you.
Jul 25, 2013 | Microwave Ovens
Need manual for ge jes738wj02 microwave oven.
Go to managemylife.com and enter your model number under the "Manuals" link. Your owner's manual is listed in .pdf format and can be downloaded or printed for FREE. For your convenience, here's a direct link:
http://www.managemylife.com/mmh/owner_manuals/6895/GE-Countertop-Microwave-L0521532?brand_name_search=jes738wj
If you require additional assistance, please post back and let me know. I hope you find this information helpful.
Oct 06, 2010 | General Electric Microwave Oven
GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Dec 31, 2009 | General Electric PEB1590SMSS Stainless...
Light bult in a Microwave oven is burned out.
There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The light inside my microwave JVM1650BH05 has burned out.
you have to remove the screws from back and bottom and pull top of microwave off. Then you will have access to the bulb. Don't worry, you won't break anythiing
Jan 30, 2009 | GE JVM1630 Microwave Oven
Can't get the light bulb out from under the counter microwave
the clear rubber is from the factory to keep the bulb from turning you need to cut this before you can replace the bulb . thats why the first bulb broke . there is no trick to getting them out , see if there is a glue strip on the broken bulb that if you chip off it will then turn . just be carefull what ever you do . ge thinks there microwave will die before the lights burn out ! it screams of there trust in there products . good luck
Jan 09, 2009 | GE JVM1650 1000 Watts Microwave Oven
Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Dec 23, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
119 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
