Question about HP Officejet 5610 All-In-One InkJet Printer
Looking for connection
Hi
I would like to use my 5610XI on another computor at home, when it starts to look for new hardware it's asking for the CD - which i no longer have
Is there a way to download the CD info from a HP WEBSITE so i can connect my printer to my computor - and start to print
thanks
  • Anonymous Apr 04, 2009
    scan no conetion
Scanner
Posted on Jul 25, 2008
Hi im roger when i put in my cd in the driver it wont download to my computor i have a dell computor.the green light comes on then goes of instantly.
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
you might have to physically unplug the cd/dvd drive this should activate the found new hardware wizard
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps
May 22, 2011 | Dell (7C340) CD-RW/DVD-ROM (Combo) Burner
Want to install the printer to my computer and I have put the installation cd but I cant see it on the printer option it has got a lot of Olivetti but not simple_way
a different way to install your printer is by clicking into start, then control panel, insode control panel look for add new hardware, follow the onscreen options and it will ask you like,
"is this connected", then it will show you a list of diferent components, like cd rom, scaner, printer etc. if you see The printer just click on printer and use the option i have cd and select the cd drive. and it usually will go from rhere.
if after "xxxxx conected " scrool down until you see show all devices.
it wil show you a new window with a list of many different Brands.and devices, it will be an option like HAVE A DISK click on it browse to the cd, then locate the driver and select it. it will confirm the model number and you are good to go.
another maybe easy way is just connect the printer to pc, turn it on and let the pc find what it is !!!
then a windows will say New HArdware Found click here o something like that. it usually ask you to connect online to llok for the driver online, other times it ask you to look for the driver in by itself o you have the option to secet the cd drive so it will look for the printer driver on the cd only, and it will install a matching driver. and you are good to go !!
Oct 07, 2009 | Olivetti wireless All-In-One InkJet...
Help! My Officejet 5610xi All in One won't print
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab66
Jun 26, 2009 | HP Officejet 5610 All-In-One InkJet...
My computor is windows vista and i can't download my installation cd on to it. What can i do ?
that samsung camera should work, right away, just connect the usb cable, select pc from the camera if asked, then open up computer or my computer either from desktop or start menu, open the camera drive and find your pictures inside, if your not sure which drive is the camera, unplug it, press F5 on the computer window, then plug it back in, and press f5 again you should notice the new drive and the photos are inside.
Jun 08, 2009 | Samsung Digimax S500 Digital Camera
Can not connect camera on to computor
I would make sure I had enough system resources to run the program check to make sure you aren't having a problem with the driver for the camera software it may need updating in order to properly work. you can uninstall the provided software and reinstall it. Also try connecting the camera before you turn on computer (NHW) should recognize and notify you that new hardware has been found have your disk ready and let your new hardware wizard guide you through the rest of setup. you can always ask me to further assist you good luck and much success. wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Apr 21, 2009 | Sanyo Xacti VPC-T700 Digital Camera
I lost the ability to print from my computor
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 14, 2008 | HP Office Equipment & Supplies
I have no sound device installed on my computor
Hi sir,
Its a simple problem, it can be solved easily....
  • How to solve this: You have to install the driver from your motherboard CD.
  • Then visit the http://en.wikipedia.org/wiki/Motherboard manufacturer's website and download,install the latest update.
  • You will need to install the drivers for your sound. Get the drivers
    1. the OEM's website for your specific machine if you have an OEM
    computer like Dell, HP, Sony, etc.; or
    2. the motherboard http://en.wikipedia.org/wiki/Motherboard mftr.'s website for your specific motherboard; or
    3. if you received a driver cd with the computer, use that.
    To determine what hardware you have in the machine:
    1. look at any manual that came with your computer; or
    2. go to the OEM's website for your specific computer if you have an OEM
    machine; or
    3. install the free Everest Home Edition software which will inventory
    your hardware:
    http://www.lavalys.com/index.php?page=product&view=1
Nov 03, 2008 | Computers & Internet
I need to install a software for my computor so i can put pictures off my samsung phone onto the computor using my usb cable but i dont have a disk
Normally you should not have to install the software any longer. Just plug your Samsung phone into the computer. AFter that the found new hardware wizard should come up or a display on your phone can come up as well depending on your model . It would ask you if you want to connect to the computer or something. After that go to My computer and you should see a new media or storage device there.
Please respond if you need further assistance.
Sep 07, 2008 | Samsung Cell Phones
I have a new lap top which is Windows Vista and my camera is compatable with Windows 98, ME, and 2000, how do I down loan the information to the new computor.
CONNECT THE CAMERA AND WHEN IT SAYS THAT NEW HARDWARE FOUND..DOWNLOD DRIVERS.....ASK FOR CONNECT TO NET....THATS ALL
Apr 04, 2008 | Cameras
HP Officejet 5610 All-In-One InkJet Printer Logo
127 people viewed this question
Seeker5211
Seeker5211
